Results 1 to 7 of 7
    Oct 24 2013
    nj
    19x9.5 wheels S5 cab
    I have a 2022 S5 cab Prestige and want to put new wheels on. Right now I have stock 19x8.5 with a 32 offset. Can I go to at 19x9.5 with a 25 offset to bring out wheels a tad without rubbing or modifications? The other option ito run 20x9 but I am done with 20's...ride is a killer in NJ :( I want 19's and going with wider rim will make tires look wider as well. Thought?
    Sep 28 2010
    NW NC / DE
    If you go with a 265/35 tire the 19x9.5 ET25 will work just fine.
    Oct 24 2013
    nj
    I would be running the 255/35/19 stock that came with it for now...assume that works as well. Newbie to wheel world outside of OEM :) Thanks for the help!
    Oct 27 2019
    DFW
    Don’t think you can stretch the stock tires to 9.5” wide. Won’t give the look you’re going for either.
    Just made the same change on my cab and went to 265/35 to fit the wider wheels as well.
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by monkster68 View Post
    255/35 on 9.5 works very well. Most of the S4 guys run exactly that. Here is an example -
    Slight stretch for sure. But you can burn up the 255s and go 265/35 next time for the wider look you’re after.
    Oct 24 2013
    nj
    Amazing...this is exactly what I plan on doing!!
    Sep 28 2010
    NW NC / DE
    Excellent! Happy to assist with the wheel purchase if needed.
