Thread: pully squeak
    Established Member Two Rings 2000blk1.8t's Avatar
    Jan 26 2014
    Livingston
    pully squeak
    2016 b8.5 has an annoying squeal in the pully system. Is there a component that is more likely to start squeaking? there is a ton of pullys on this thing and im not sure how to start locating it. I tried taking the belt off and spinning them by hand and couldn't figure it out.
    2016 s4 stock.
    Jan 26 2014
    Livingston
    Never mind. We plan on keeping the car for awhile longer so I ordered new tensioners for the supercharger and accessory system. As well as idlers for both and new belts. I would think that should cover it.
    2016 s4 stock.
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    Quote Originally Posted by 2000blk1.8t View Post
    Fire the parts cannon!!
    That's how I solve these things sometimes. Just for fun, try swapping only the belts first and see if it solves it.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Jan 26 2014
    Livingston
    well, I figured that if one bearing is showing wear and squealing, some of the others aren't far behind. I can usually hear the difference between a squeaking belt and a bearing. It definitely sounds like a bearing.
    2016 s4 stock.
    Sep 16 2020
    West Michigan
    Could pull the supercharger belt off to see if it is that set of pullies or not to narrow it down?
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
