A bit off topic here, wasn't sure where to posit it. I am having some issues with a VW golf mk5 1.4 16v, but it has the same engine as the Audi A2. Didn't see an A2 topic so I thought I'd ask here.
Had the timing belt tensioner bolt brake clean off while on the freeway, turned engine off straight away and just rolled onto a off ramp. Towed the car home. Pulled the rocker cover with cams and found about 4 rocker arms destroyed, pulled the head out and found all 16 valves bent, luckily no piston damage thank god. So got the valves changed and head checked. Found that 3 stems that the valves travel in where damaged so where changed, and also 3 hydrolic lifters where stuck in the head, they where welded out and holes repaired.
Got the head back, put it all together and am getting slight misfire, the engine runs quietly and smooth apart for the slight misfire, on high revs ok but on idle the revs keep dropping and nearly stalling. VCDS gives me no engine fault codes at all. So not sure what to do next or what to check.
I have re checked the timing numerous times and are certain everything lines up (all the timing marks) and used cam locks to lock both cams in place. Have done timing on these motors before never had any issues, totally stumped with this.
All four coils where changed about 3 month ago and are new. So I also think if coils where bad VCDS would give me some coil related fault codes no? I'm getting no timing related codes either.
I know you peps have a wealth of knowledge so I thought I would ask.
Much appreciated for any advice
