Results 1 to 4 of 4
    Jan 04 2023
    Do knock sensors go bad often?
    I'm changing the thermostat out and see the 2 knock sensors. It looks like they'd be a pain to replace normally but I can easily do it now. This engine has 90k miles on it. I don't want to spend the money to replace them if they don't go bad often. Does anyone have any experience with them?
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    In 12+ years of tinkering on VAG engines i've only ever seen one knock sensor go bad on a 1.8T, and it was probably loose, then over torqued and cracked, sensor itself was probably fine but giving erratic readings due to mounting tab/bolt hole.
    They are usually pretty stout, i'd say skip it.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Jan 04 2023
    Awesome thank you
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2011 Police Interceptor
    Stinky Island, NY
    Short answer is no. The only time Ive had an issue with them in my car was when the mechanic pulled out the wires by accident. Just replace it with an OEM sensor and nothing aftermarket
    Sent from my SM-S908U using Audizine Forum mobile app
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
