Results 1 to 6 of 6
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 24 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Steering column u joint
    Has anybody replace the steering u joint that’s in the steering column? I think mines got play literally the only thing left I haven’t replaced. Curious if anybody else has come across it as a problem
    Veteran Member Four Rings belms4's Avatar
    Apr 17 2019
    2000 silver S4, 2001 imola S4, 2002 Avant nogaro RS4 conversion
    I haven't personally ever heard of anyone having to replace that. What exactly is the issue? Slop in the steering wheel?
    And what all have you replaced? Inner tie rods (the ones attached inside the steering rack boots that have the ball joints) are always a good place to start if you haven't touched those yet.
    Sent from my SM-F721U1 using Audizine Forum mobile app
    Aug 24 2008
    Santa cruz
    Kinda like a floaty vague disconnected feeling, sort of feels like one side has more play than the other when turning the wheel. New inners and outer tie rods new rack new lower control arms new upper control arms new shocks and alignment the rack bolts aren’t loose. It used to feel good like a go cart then my rack went bad and I’ve been chasing it ever since. If I shake the wheel back and forth u can sort of tell but without another s4 to try out its kinda hard.
    Aug 24 2008
    Santa cruz
    This thread is the best I can find but no one ever updates their fixes
    https://www.audizine.com/forum/showt...column-u-joint
    Apr 17 2019
    Interesting old thread. I have the dashboard out of my avant build for restoration currently and went and had a look at that joint. This particular one has 183k miles on it and the u-joint is tight as can possibly be. No play whatsoever. Any turning in the column at all moves the joint without any spare movement.
    So I guess you can check yours the same way. It's so far back under the dash I'm not even sure if the knee bolster would need to come off. Just unlock the steering wheel with key and turn it tiny amounts and see if that joint wiggles with any looseness before moving the lower section.
    Aug 24 2008
    Santa cruz
    I replaced the one down by ur feet at the firewall where it connects to the rack I’m talking about the actual column I think there’s one in there but I’m not positive what’s exactly in there
