Results 1 to 34 of 34
Thread: WTB: Tial 770R
    Oct 15 2021
    2000 Audi S4 - Full Stage 3, 2003 VW MK4 GTI - Big Turbo / 2016 Subaru WRX Limited
    Illinois/United States
    WTB: Tial 770s
    I know these are becoming increasingly harder to find...
    Looking for a set of Xona Rotor 770s or regular 770Rs preferably in good condition that don't need to be rebuilt. Thanks!
    Established Member Two Rings Euroheadache's Avatar
    Feb 28 2020
    B5 s4
    Long Island
    I have a brand new set of XR770’s in the box with inlets and all lines / downpipe flanges . Lemme know
    Oct 15 2021
    Quote Originally Posted by Euroheadache View Post
    Got your PM. Reply sent.
    Oct 15 2021
    Robert11, I tried replying to your PM but your inbox is full.
    Aug 20 2018
    Melbourne, AUS
    Should look into these.
    TTH-800 2.7TM RS4 / S4 B5 Turbochargers +++
    https://r.tapatalk.com/shareLink/top...ink_source=app
    Oct 15 2021
    Quote Originally Posted by SENN4 View Post
    I looked into TTE but very hesitant with the amount of turbo failures I've seen pop up within the past 2 years for anything above TTE-600.
    Registered User Four Rings
    Sep 01 2013
    Sweden
    I agree with you on TTE (theturboengeers). You are correct. Stay away from them.
    But those offered to you are not TTE. Its 2.7TMotorsport chargers made by TTH (turbo-technic-hamburg) to our specifications.
    These turbos are stout.
    Aug 20 2018
    Melbourne, AUS
    Quote Originally Posted by evalegacy View Post
    Not to be confused with TTE, they use china wheels.
    TTH only use genuine BorgWarner wheels and are absolute top quality guaranteed. OE fitment aswell.
    Veteran Member Three Rings Shahek's Avatar
    Feb 14 2018
    Sunland/CA/US
    Quote Originally Posted by Mocke View Post
    Lol stilllllll at it.
    Registered User Two Rings RS6Tuner's Avatar
    Feb 15 2017
    RS4 B5 TTE960 / 992 4S TTE740 / MINI COOPER S 200 / VW T6 4MOTION 210
    UK
    TTE turbochargers are backed up with a TTE TROUBLE-FREE Warranty for 1 year. Even if you drop a 10mm socket in one your covered.
    Oct 15 2021
    Quote Originally Posted by RS6Tuner View Post
    That sounds quite a bit far fetched! I highly doubt TTE or any reputable turbo brand for that matter, would willingly replace their turbos for free under warranty from damage in such a manner. Most companies have more scrutiny for warranty claims and after an investigation where it's completely evident failure is due to owner or shop fault, especially in the case you stated, would certainly void the warranty. Which is also a far cry from the multiple instances I've seen where TTE refused to warranty their turbos from failure only 1-2 months after install from normal use. Even hearing multiple stories where TTE wouldn't warranty turbos directly after professional install due to "oil starvation" and blaming the issue on the customer's oil sump failing (which it wasn't, in multiple cases) makes me very hesitant to proceed with said company.
    Feb 15 2017
    UK
    Well it is true.
    1 YEAR TROUBLE FREE WARRANTY is now offered to cover even when there is oil starvation or not if the customer or internet thinks.
    The TurboEngineers Trouble Free Warranty
    Any turbocharger/s purchased via TTEGLOBAL.COM will receive a 1 Year Warranty of the original purchase date. If for any reason your turbocharger/s fails or has an issue you can return it to TheTurboEngineers for a free overhaul and recondition or replacement depending in availability or the turbocharger/s problem.
    *terms & conditions are 1 year of the original purchase date and too the original purchaser.
    Oct 15 2021
    Note the "TERMS & CONDITIONS APPLY" statement.
    https://tteglobal.com/terms-conditions
    Under the "Warranty" subsection:
    "It is the buyer’s responsibility to ensure that the products purchased from TTE Global are fitted correctly by an experienced professional and for their intended use, while using the correct associated hardware. Failure to follow these guidelines will void any warranty. TTE Global will not be responsible for any loss or damage."
    Pretty clear statement there! I don't think dropping a 10mm socket into your turbo or inlet to get sucked into the turbo, constitutes as "correctly" or "intended" and would very likely void the warranty. You also have to send the "defect" item back first to be inspected for warranty, before rebuilt/replacement; in your case although extreme, inspection would show damage from foreign object introduced into turbo, and not a fault from assembly or manufacturer defect and surely void the warranty.
    After the nightmare stories I've heard from TTE pushing back simple warranties that appear legitimate, or at least in cases far milder than destruction from a socket example, I'm not willing to take the risk of wasting my time and money buying two, having legitimate failure issues, then sending one/both back for them to turn around and erroneously void the warranty. I'll stick with Tial/XR or go with GT turbos.
    Feb 15 2017
    UK
    Cost of shipping Turbocharger/s back to TheTurboEngineers will not be covered and is the responsibility of the customer, all return details will be sent to the customer once a return has been opened and a return number is generated. TheTurboEngineers will cover the cost of shipping the reconditioned or replacement turbocharger/s back to the customer.
    Turbocharger/s sent to TheTurboEngineers without a valid returns number will not be serviced and may not be covered by the warranty.
    Any service work or labor or expense untaken to remove the faulty turbocharger/s will not be covered and is at the customers expense.
    Feb 15 2017
    UK
    You are confusing with other parts we sell like THE TUNER, FORGE, 9M, DO88.
    Apr 07 2011
    Home of the mighty beaver
    Malaysia... but yeah.
    Feb 15 2017
    UK
    Sorry but this is incorrect info no matter what Mocke trys to tell the internet. TTH are using China and Malaysian components like TTE are in their turbochargers and B5 hybrids.
    See here look at the non oem 9 blade China exhaust turbines in there rs4 /rs6 hybrids https://www.turbo-technik-hamburg.de...-4b-750ps?c=23
    Oct 15 2021
    I don't care... Remind me again, where in the title do I say looking for TTE or TTH?
    Veteran Member Three Rings xFvse's Avatar
    Sep 08 2016
    Wuhan
    Just get the tials. Those rs6s turbos wont pack the same punch you are looking for with the tials. As much as those guys overbore the housings, they will still be limited.
    Aug 20 2018
    Melbourne, AUS
    I beg to differ. I tried my luck with TTE once and got absolutely burned.
    I was one of the first if not the first to order the ‘all new’ at the time TTE880’s. After some delays my build was finally ready.
    First pull on pump98 fuel wastegates locked at 30% very conservatively and my turbo’s blew up…catastrophically! Literally shattered in pieces. I have several photos to prove everything.
    Setup was built professionally by a raceshop.
    4000E+ down the drain.
    Where is my warranty?
    Aug 20 2018
    Melbourne, AUS
    These are my current TTH’s with genuine BorgWarner 12 Blades and THE 8” Housings.
    No 9 Blades here.
    Feb 15 2017
    UK
    Well TTH are as are near all turbocharger company's and honestly quality of those far east parts are very good.
    Sorry you had an issue i don't know the specifics on your case but we do sell thousands of trouble free turbos yearly. There can be issues in tuning and fitting aftermarket parts or OEM parts and it can be painful.. Ive had my fair share of b5 problems with over a decade of ownership so i totally get it. #b5life we used to say me and friends.
    TheTurboEngineers Trouble Free Warranty was introduced this year to avoid issues and upset to a point for the customers no matter the reasons.
    Feb 15 2017
    UK
    Someone must have contacted TTH. Today the images showing the 9 blade China turbines (with a clip) on there RS4 Hybrids has been removed from their webshop. I did grab a screen shots before they deleted images.. see below
    Aug 20 2018
    Melbourne, AUS
    Please don’t smear me trying to sell my TTH turbos.
    It has nothing to do with your 9 blade’s.
    My turbochargers are specified and delivered by 2.7TMotorsport.
    They are 12 blade BorgWarner made by TTH as you see in pictures.
    These are your blown TTE880 with 9 blades.
    I think anyone can see the difference.
    May 09 2012
    Virginia
    Feel for the OP. All he wanted was some Tials. This turned into the typical BS that we have come to expect.
    Feb 15 2017
    UK
    Smear you ? I just corrected your incorrect statement "Not to be confused with TTE, they use china wheels TTH only use genuine BorgWarner wheels and are absolute top quality guaranteed" Being pushed about by Mocke when TTH also do and are as is shown. I didn't know you are selling ???
    Established Member Two Rings MirnesBeg's Avatar
    Dec 06 2018
    St Louis, MO
    OP I’ve got some G25 for sale if you’re interested. Brand new never installed, look at my for sale post.
    Dec 06 2018
    St Louis, MO
    https://files.fm/f/rp7ph45dq
    Aug 20 2018
    Melbourne, AUS
    Quote Originally Posted by MirnesBeg View Post
    RS6Tuner… Any warranty on the above??
    Sep 15 2014
    South Dakota
    I have a set of 770's with inlets and down pipes if your still looking. Just PM me and I can give you more details.
    Feb 15 2017
    UK
    Yeah sure he's covered.
    ill just leave this here too
    RS4 Limo v2 TTE1200 9Bladeturbines
    Veteran Member Four Rings AudiAR01's Avatar
    Dec 27 2019
    West Virginia
    God these two are still at it. I left the zine for like 16 months and they were arguing back n forth. I see some things never change.
    Sent from my SM-A136U using Audizine Forum mobile app
    Dec 27 2019
    West Virginia
    Still for sale?
    Dec 06 2018
    St Louis, MO
    Quote Originally Posted by AudiAR01 View Post
    Still for sale?
    Yes, I still have them and would sell.
