Results 1 to 4 of 4
    Junior Member Two Rings
    Jan 02 2012
    Harstad, Norway
    Exhaust gas temperature sensor 2
    Hi!
    Where is the EGT sensor #2 located in the 2011 2.0tdi?
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Here:
    Jan 02 2012
    Harstad, Norway
    Ok, so there is no sensor/sender #2. That explains why vcds shows 0⁰C on sensor 2. Thank you for the reply👍
    Oct 10 2010
    Sarajevo, BiH
    This is an official document of the VW group, they don't mark the sensors that way (sensor 1, sensor 2......)
    Look for the answer on the VCDS forum
    If you have VCDS you should have something like this
    5260 - Sensor 1 for Exhaust Temp Bank 1 G235
    P0544 00 [047] - Circuit Malfunction
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 14
    Mileage: 133283 km
    Date: 2016.11.07
    Time: 17:55:29
    8187 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
    P2080 00 [237] - Implausible Signal
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 230578 km
    Date: 2000.00.00
    Time: 00:00:00
    Compare it with the picture I posted and you will know where that sensor is
