Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Established Member Two Rings mrg_B8TFSi's Avatar
    Dec 24 2021
    Audi 2013 A4 Quattro B8, 6-sp man, Audi 1998 A6 Quattro C5, Ford F250 XL 5.4L 4x4
    Northeast PA
    Upper Pinch bolt
    Hello well it’s time to replace my upper and lower control arms on my A4, I notice there is a lot of play and the car isn’t tracking tight as I know it should be. I did put it up and noticed the bushings are cracked and separating on the uppers and lower rear on the passenger side. I have the entire Meyle HD kit and am gonna do both sides including the sway bars. However, after removing the passenger side upper pinch bolt nut (pinch bolt holds the upper ball joints into the spindle) the bolt is frozen/seized..etc I can’t budge it, although interestingly it’s clean the threads look brand new but it’s original and this car has seen its share of salt.. I’ve had it soaking in PB blaster and have been hammering the bolt (brass hammer) to try to shock load the penetrating oil into the bolt. I’m not getting the bolt to turn at all.. gonna have to put heat to it. My question is has anyone had difficulty in this pinch bolt removal? I’m wondering if excessive heat to the aluminum spindle will cause any damage to its structural integrity? I know many videos do show and use Mapp gas, which is what I’m about to use next, and hopefully I can get the bolt to spin so I can punch it out. Anyone ever had to heat the spindle for this? How’d it work out? I know I’m not gonna bang on that aluminum which would result in cracking it, but hopefully heat work crack it. Thanks.
    Established Member Two Rings LifetimeAudi's Avatar
    Nov 30 2020
    Durham, NC
    We have plenty of spindles in stock, lifetime part replacement warranty.
    Senior Member Three Rings WHT13AR's Avatar
    Oct 09 2022
    '07 GT500, '21 Silverado, '79 Mustang Coupe, 2015 Allroad, 2011 Avant (beater)
    Michigan
    I used MAPP heat and worked the head of the bolt while heating. Put a crap nut on the end of the bolt to hit it. Dont hit it too hard, you can damage other parts. Also, when heating, heat the bottom, away from the upper joints so you dont melt the boots. For me, it eventually came out enough to use an air chisel on the underside of the bolt head and it finally worked out. Be sure not to try and turn the bolt more than it wants to, you could break the head off and be in bad shape.
    There are a couple of different tools you can get to push it out easily. One is like $500 and works like a little press. The other, not sure on price, is a drill guide to drill the bolt and then drive it out with a drift. If you're patient, you can get it out of there with standard hand tools and just replace the bolt.
    Dec 24 2021
    Northeast PA
    Quote Originally Posted by WHT13AR View Post
    Thanks .. yeah gonna replace all the hardware I have everything and my plan was to put the heat to it and work the 16mm head of the bolt to get it turning.. then with the old head on the bolt will tap it to get the bolt moving backwards and eventually using a drift to punch it out. I do t want to drill as I fear I could go into the spindle.. oh I don’t care about the ball joint boots as I know those will get toasted like a marshmallow they’re getting replaced.. thanks good advice
    Dec 24 2021
    Northeast PA
    I’ll look into this
    May 09 2012
    Virginia
    Replacing an upper pinch bolt on an Audi is a right of passage. On multiple platforms I have encountered the “stuck” pinch bolt.
    I too, use MAPP gas for the tough cases and have the schwaben tool from ECS.
    Veteran Member Three Rings B8Buckeye's Avatar
    Mar 14 2005
    2011 Audi A5 Cabriolet - Ibis White and 2016 Mercedes Benx Metris conversion van - Obsidian Black
    NW Ohio
    Good luck to you. I just had the complete Meyle control arm kit installed with upgraded urethane inserts. I also had ECS coilovers installed at the same time. After 105k miles, the original suspension was showing its age. The upgrades made a HUGE difference in steering and suspension feel - like a new car.
    2011 A4 Avant 2.0T Quattro ZF8 - Brilliant Black - Sport & Cold Weather Packages
    Magma S4 Seats & Door Cards with Brushed Aluminum Trim, B8.5 S-line Auto Shift Knob, RSNav S3 10.25", 19" OEM 5-Arm Cutters, RS4-style Honeycomb Center & Fog Grilles, deAutoLED Turns & Fogs, OEM B8.5 Euro LED Tails, OEM S-line Stone Guards & Rear Valence, IE HFC/DP, Milltek CBE, UM Stage 2, ECS Coilovers
    Oct 09 2022
    Michigan
    Rear shock lower bolt is a monster too. Broke one, not looking forward to the other.
    Dec 18 2015
    OH
    How do you break a bolt that large?
    Oct 09 2022
    Michigan
    Quote Originally Posted by rj124104 View Post
    Galvanic corrosion. Pipe on 1/2" breaker bar, SNAP! Had the pinch bolt out already so I took the whole knuckle off and fixed it on the bench.
    Feb 15 2016
    Cambridge,Ontario
    lol you are talking about the pinch bolt from hell... pbfh
    it is the most universally hated bolt by all DIY guys in the northern hemisphere...
    https://www.youtube.com/watch?v=yjKqqHjM_KM
    decent vid
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 24 2021
    Northeast PA
    I don’t understand what VAG design team was thinking when they designed this assembly with Aluminum spindle and steel bolt with no coating or corrosion inhibitors?
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by mrg_B8TFSi View Post
    well they did redesign the bolt..... once you get the old one out lol.
    1976 Yamaha XS 360
    Dec 24 2021
    Northeast PA
    decent vid
    Thanks iceman for this video.. wow no wonder shops turn this job away.. ok I’ll try this technique but will try the ECS tool first I have access to that removal tool. Sounds like you’ve done this job before, did the knuckle get damaged? Did you use the press to pull out the ball joints or pickle fork or hammer on them?
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Really? Can you share more info on that? I didn't know that bolt is different now.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by RockJGC View Post
    New bolt is "stepped" in the center.
    Dec 24 2021
    Northeast PA
    Was hoping it was titanium lol
    Sep 28 2014
    NY/NJ metro area
    Nice.....so less contact area to make it easier to remove should it get corroded? Is that the idea?
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    Getting these bolts out is my worst memory of working on my B8 A4 that lived it's whole life in western NY. Wish I had known about the Schwaben tool.
    Be careful with heat, it is needed but remember the steering knuckle is aluminum. Took a full Saturday to get just one bolt out, with the dis-similar metals it is like the bolt is welded to the knuckle.
    Dec 28 2006
    Western Maryland
    Yep. And it lets you pack some anti-seize inside the knuckle.
    Veteran Member Three Rings gdlkn84as's Avatar
    Apr 25 2012
    2006 B7 A4 S-line 2.0T (Sold) - 2008 PT Bruiser (Long Story) - 2003 Kawasaki Z1000
    Greenwood, IN
    Took me 2 days to get one out on my B7. The other side took about 4 hours....
    Well, 4 hours until I broke the knuckle that is.
    2006 B7 A4 S-Line 2.0T - SOLD
    -Making my return to the 'Zine-
    2016 B8.5 Allroad
    PP+, Sport Interior, DS, VAG'd
    2003 Kawasaki Z1000
    Dec 24 2021
    Northeast PA
    So this is the pinch bolt from the rear upper right side.. I don’t feel or see any stepping for the ball joints to sit against.. all of the control arms (all four uppers) came with the bushing mount bolts and a pinch bolt, this was from the Meyle HD kit from FCP should I be using these upgraded bolts? Did FCP put the incorrect bolts in the boxes? Thanks IMG_0929.jpg
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    I'm so glad I don't live in the salt belt. I've had a few that were tricky. Actually, my car is from Illinois and has seen a few salty winters. I did mine a couple months ago; first UCAs I did that fought me in a long time. Blue wrench and air hammer took care of it(even saved the bolt).
    Good times.
    B6 S4, B8 A4, 8P A3, and something, something.
    Sep 03 2014
    2014 Audi Q7 Premium Plus, 2014 Audi A4 2.0T Quattro S-Line
    Ellicott City, MD
    I'm still amazed that Audi/VW has not done something to correct the design of a stupid bolt after decades of putting these in their cars. My first run-in with one of these was on my wife's '98 Passat. The one surefire method I found for getting these bolts out is to use a Dremel tool in the slot n the spindle closest to the bolt head and cut through it as far as you can without damaging either the spindle or the upper control arm boot. The take a socket wrench and tighten the nut on the other end to jack the bolt out. Use some old lug nuts as spacers when you get down near the end of the threaded section and repeat as necessary until the bolt comes free. Clean out the hole in the spindle to remove all of the old rust and slather lots of anti-seize compound on the new bolt before installing it. I have never had to use heat on the spindle to get a bolt out using this method, and I've swapped out quite a few of them.
    Dec 28 2006
    Western Maryland
    I don't think they gave you an incorrect bolt. They just didn't give you the updated version (WHT007963)
    Oct 15 2019
    '12 TTRS, '10 A4 Avant
    Golden, CO
    I used the method from the Passat forums where you cut the head off the bolt and use a coupling nut to pull the bolt from the opposite side. Got the bolt out on one side with no issues. When doing the other side I forgot to shove washers in the spindle gap and broke the tab off; had to get a new spindle.
    Feb 15 2016
    Cambridge,Ontario
    only tipmi can provide if it hasn't been posted is make sure you put ( hammer) a washer in each gap of the knuckle where it is designed to pinch .
    number one reason knuckle fails is people forget this and knuckle fractures at opposite side of knuckle.
    depending how the bolt seized it can actually pull the gap closed
    Sent from my SM-G973W using Audizine Forum mobile app
    1976 Yamaha XS 360
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by hamfisted View Post
    Yea I have that one bookmarked. I used that once about 15 years ago, see the link below. Since then, I just anti-seize the crap out of it, haven't had a problem since then.
    https://www.passatworld.com/threads/...y-pics.233225/
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Dec 24 2021
    Northeast PA
    Upper Pinch bolt
    Well after a couple cycles of map gas heating and PB blaster soaking I finally got out the right upper pinch bolt. No cutting or drilling.. I got the bolt spinning and then I put the air hammer on the nut .. I used the nut as a centering guide for the hammer but once the bolt was flush with the upright I put more heat on the spindle and then with a wide “V” notched chisel bit I air hammered on the shoulder of the bolt head and slowly the bolt was moving.. I got it out all in one piece .. I did open the ball joint stem gaps a tad with chisels but I’m not sure that was doing much.. the air hammer was the trick along with heat.. once out I cleaned the bore throughly with parts cleaner and penetrating oils and wire brushed it shiny clean.. never seized the ball joints and with a jack under the knuckle the new ball joints slid in easy.
    This was a b*tch of a job but stay patient and use heat and air hammering on the bolt.. never hit any aluminum. It’ll eventually work out
    Apr 05 2014
    Texas
    Thats a W
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Bubbling this up, I snapped the head off on the driver's side pinch bolt but the nut came off easy. This was after soaking it all with PB and heating it up with an induction heater I have.
    Am I screwed and need to get a new knuckle?
    Or should I now try double nut on the bolt side to see if I can get it to turn?
    Sent from my SM-N976V using Tapatalk
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Dec 24 2021
    Northeast PA
    I’d try to heat it with mapp then PB blast it.. back n forth heat cycling then try to air hammer it, there is a pinch bolt air hammer kit for this upper bolt
    Jun 12 2013
    I just found the tool, thanks!
    Read on another thread this isn't a threaded area so the bolt is just corroded in there. That's a bit of a relief.
    Time to get a MAP tank too from the hardware store.
    I'll be taking the knuckle off anyways as I'm replacing/upgrading everything. Shock, springs, upper arms, lower arms, tie rod, trailing link, wheel bearing, and ball joint. Lol
    Build Thread
    Feb 15 2016
    Cambridge,Ontario
    you can use the nut side as a puller.. put something in the pinch gaps like a washer to stop it pinching closed as you don't know where it's binding .. Put the nut back on with washers and see if you can pull the rest of the bolt through..
    you may need to keep adding washers if it starts to move. and cut pieces off the end of the bolt as it might hit the inside of the fender . heat will obviously help too.
    1976 Yamaha XS 360
    Dec 24 2021
    Northeast PA
    Upper Pinch bolt
    Yep great advice keep working the bolt if you can get on it, with the head snapped off could be flush to the knuckle.. so as mentioned you might consider spreading the knuckle with washers or a thin chisel..etc that will help get that snapped bolt moving… once you get it moving you should be able to finally drive it out with air hammering. Yeah welcome to the rust belt you people on the west coast have no idea how easy you have it lol.. I limit it to the west coast to the areas of low humidity because there is no such thing as low humidity east of the Rockies, even high humidity without salt causes enough condensation over time to rust a car
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    You can also mix up some 50% acetone (edited: not rubbing alcohol) and 50% ATF. That might soak in better than PB Blaster.
    Jun 12 2013
    Quote Originally Posted by Chillaxin View Post
    You can also mix up some 50% rubbing alcohol and 50% ATF. That might soak in better than PB Blaster.
    I've never heard this trick before. Interesting.
    Build Thread
    Veteran Member Three Rings SNice's Avatar
    Aug 06 2019
    Philadelphia
    Mine was stuck and corroded - 120k; entire life in PA/NJ.
    I twisted the head off (weakened it with a cut through the slot).
    Then I put together a diy tool like the one in the video below:
    Threaded rod, some pipe, coupler, nuts, and washers.
    Got the rods and couplers from McMaster carr
    Pulled it right out!
    https://youtu.be/6tA_VCBMrb4?si=igLLVzTLAoix0WlV
    2014 A4 B8.5 - AUDI _ EFR 6758 / WPT Stg. 3 Flex-Fuel TUNE / WM Injection / Custom HFC / JHM D-Pipe / AWE FMIC & EXHAUST / APR INTAKE / KW V3
    2002 SV650 - SUZUKI
    1989 nt650 HAWK GT - HONDA
    1972/4 r5/rd350 Hybrid (WIP) - YAMAHA
    1971 r5 350 (basket case) - YAMAHA
    Aug 06 2019
    Philadelphia
    Here’s the “tool”
    2002 SV650 - SUZUKI
