Results 1 to 13 of 13
    Sep 11 2011
    2022 RS7 & 2201 TTRS
    DFW
    Vibration highway speeds
    2021 TTRS: Long story short, have had off and on vibration (steering wheel) around 80/85 mph since the car was new. Car originally had the OE P Zeros and noticed severe vibration right when we bought it, dealer verified and did a road force, moved the lowest road force readings to front, etc.
    Installed a set of 4 PS4S after 2 failed attempts on the OE P Zeros, get them roadforced and one is right around 23 lbs so I get that one tire replaced. Dealer does another road force with the new tire and gets all 4 down to 12 lbs or below. I am still getting some vibration around 85 mph, it's better overall but its still there (sometimes it's barely noticeable, so its now sporadic at least). Note the front tires are both below 8 lbs road force (and the vibration is in the steering wheel so this is confusing me a bit).
    I know these are incredibly low profile tires with very little margin and obviously it's a very sensitive suspension setup; but has anyone else had ongoing issues with highway vibration? I am going to try and have the dealer check the wheels next, but I assume if the wheels were the issue the Hunter Road Force machine would diagnose that as I do believe it check that as well during the process. Any thoughts?
    2022 RS7 & 2021 TTRS
    Retired: Macan S, 2019 RS5, 2020 TTS, 2019 S4, 2017 TT, 2014 A6 TDI, 2014 S4, 2011 A4 Avant, 2011 Audi TT Roadster
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Quote Originally Posted by Jprieur View Post
    Any thoughts?
    Go the speed limit?
    Seriously, while wheel balance is the most obvious culprit of vibrations in the steering wheel I feel like that has been pretty completely covered (different tires, multiple balances, moving tires around, etc). I mean if you've even changed tires and the same issue remains, it might not be the normal issue but something else in the suspension or rotating assy. You know what they say, if you rule out the possible, then the remaining, no matter how improbable, must be the issue. Heck, makes me wonder if maybe there's a small defect in the steering gear (electric with feedback afterall) where it's causing vibrations with the motor? Wild and crazy to even say but hey.......no idea why speed would matter there either but as complex as these cars are now, I've seen some crazy stuff.
    I tracked the OE P Zeros and never had vibrations at any speeds, I've been running the PS4S's (on different wheels) and have not had issues and neither required more than one balance.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Senior Member Three Rings McTTRS's Avatar
    May 09 2017
    Alabama
    Quote Originally Posted by Thumper3 View Post
    Go the speed limit? [:D
    If this is the case then perhaps changing the drive select setting will impact the problem.
    2022, 2021, 2020, 2019, 2018 TT RS - 2016, 2010, 2019 TTS - 2006 Porsche Cayman - 2001 TT Quattro
    Feb 20 2014
    Port Orange, FL (Daytona Bch)
    I've had the same issue on my 2022.....dealer comment was aftermarket suspension-H&R springs. Mine comes and goes too. Pzero's and I plan to replace soon with Michelins.
    Current: 2022 TTRS Turbo Blue, Xpel clear bra, H&R Sport Springs, ceramic coated.
    Past: 2019 TTRS Turbo Blue, 2018 TTRS Nardo Grey, 2015 Audi TT S Competition Package & 2011 Audi TT S, Black on Black
    Remember: Hit em with the Hein!
    Sep 11 2011
    DFW
    Quote Originally Posted by McTTRS View Post
    Ive tried changing modes (I actually have the fixed suspension so its not changing the suspension), and have also tried running the same speed in neutral; doesn't change and still have the vibration.
    Ive also tried bumping up tire pressure, running for a while to warm up tires to rule out flat spotting of the tire.
    Im at a loss. . . . wondering if maybe wheel bearings are the culprit
    Junior Member Two Rings
    Feb 17 2022
    Elko Nevada
    Are you on stock wheels? I know on my S3 I had to run hub centric rings for some wheels that were a bigger hub bore then stock, it haunted me for a while till I figured out the lug nuts don’t center the wheel perfectly.
    Sep 11 2011
    DFW
    Quote Originally Posted by Pharp View Post
    Everything on mine is stock, no spacers. Dealer, in previous attempts to fix, was very careful in property mounting wheel to ensure no issues with uneven torque on lugs, etc.
    Veteran Member Four Rings Over9000's Avatar
    Oct 14 2013
    ¯\_(ツ)_/¯
    I vaguely recall one or two other cases of people chasing vibrations at highway speeds in here that ultimately ended up being traced to the brake rotors. Something else you may want to consider.
    Doug (a.k.a. Dung from No Lube, No Problem)
    '21 TTiesRS TeamOEM
    Nov 25 2013
    Ottawa
    Before you start tearing into the car looking for faults I would spend a lot of time checking the roads that you travel. The rollers used to pave today's roads can create ripples. New highways are more prone to have problems because heavy trucks tend to even out the ripples after a couple of years of traffic. Last Summer I found fresh pavement with huge ripples that were very clear even at low speeds. A few years ago I discovered long stretches of a new highway had ripples.
    Sep 11 2011
    DFW
    Quote Originally Posted by steve111b View Post
    I have ruled out pavement, so it's definitely not that. It has to be something rotational, so still thinking bearings or based on the input here rotors. I've always thought with rotors you would would have to have a massive deviation to feel vibration caused by rotors (when NOT braking).
    Sep 11 2011
    DFW
    Quote Originally Posted by Over9000 View Post
    Thanks, I did just notice that one of the brake rotors (pax side front) has some scoring where the rotor meets the disk. The other side is completely normal.
    Feb 20 2014
    I hear a lot of little rocks/pebbles between the shields and the rotors. Wonder if that is what could have happened to cause these marks?
    Sep 06 2010
    Germany
    I know the thread is a few months old but did you ever figure out the source of vibration?
    I know some people here will say drive speed limit, it's the roadway, wheels, tires, etc. Well I have my car in Germany and for some folks that get to drive 200+ km/h routinely the vibrations suck. Other than some mild local ECM tuning, the car is completely original. A new set of tires did nothing, I have OE Audi brakes and rotors. Several inspections have revealed nothing amiss. Maybe for me it's because I have a convertible, I can't tell. I say this because for the very brief period the weather here is appropriate to put the top down I have observed significantly less vibration at speed. I've tried playing with that automatic rear spoiler and it really doesn't change much. Only thing I've ever read is the rubber couplers on the driveshaft could be the culprit but they look fine and my car is low mileage.
    2011 A4 Avant S-line
    2016 TT Roadster
