Results 1 to 8 of 8
    Junior Member One Ring
    Oct 29 2021
    Astoria, NY
    Torn between resonated cat backs from AWE and Milltek
    Hi all,
    I'd like to improve the quality of the sound my S4 makes but don't want to make it too much louder than stock. Drone must be avoided at all costs. I was curious as to whether people have heard both the Milltek and AWE resonated cat-backs and if they have opinions on the difference. I've listened to so many sound clips on youtube, but they're not all that much help.
    Senior Member Two Rings Goonz's Avatar
    Dec 06 2019
    Boston, MA
    check your PM, I have a fully resonated Milltek exhaust and can message you exhaust clips.
    '22 e-tron S Prestige
    SOLD '19 Audi S4 / GW/Magma / B-Optics / S-Line / B&O / Milltek CBE / 034 Rear Sway/Strut Brace/Mounts/Front UCL/LCL / 034 Stage 1/ APR PEX Intake / RS Grille / H&R Springs / Audi Blackline Taillights / Matrix LED Headlights
    Jun 05 2017
    B7 RS4 - B9 S4
    North Carolina
    I have had a custom exhaust with the resonators removed and a catless DP. Although this setup sounds really good, there was drone which is why I switched. I'm currently running the AWE Switchpath with the stock DP, no drone with this setup. Are you gong to be running the OEM DP, HFC, or catless?
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    i have never been a fan of AWE exhaust on any car i've heard it on, they all have this weird tone that's heard across all platforms. i have done miltek on 6 of my cars, any time i've strayed away and went with something else, i always ended up going back and buying a miltek. no different on my b9, love it. i'm running a resonated miltek with catless cts downpipes.
    Go with the resonated miltek, it will give you an OEM+ like sound. plus the tips look great, particularly the titanium ones
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Aug 12 2021
    FL
    I wouldn’t do Catless, Highflow maybe but my catless is to high pitch no matter what I’ve done. From Borla to additional vibrant resonators. Wot sounds great but normal driving it sounds like crap. And by loud, I’m hard of hearing and it’s still loud lol. My db app shows I cruise at 75-77db and that’s with complete dynamat
    Apr 09 2022
    Tulsa, OK
    I have a ton of videos up with the ECS exhaust. Construction is the best ive seen in a long time for any aftermarket exhaust, sound is incredible, and with the valves closed, its no louder than the factory exhaust with the valves open. Its also quite a bit cheaper than the other systems, and looks fantastic with the huge black tips. I wouldnt hesitate to buy it again over the AWE or Miltek. My opinions on the build quality of the exhaust is based on 20 years of fabrication, welding and exhaust building experience, so its not just a "looks the same to me" opinion.
    https://www.audizine.com/forum/showt...d!-Pics-inside
    2018 Audi S4 - 10.2@133 full weight - IE Tuned!
    Instagram - TulsaMike4
    YouTube - TuksonMike
    IE stage 3 tune on E70 * Pure 750 Turbo * Carbnlab Downpipe and intake tube with modded stock air box / BMS Filter * ECS Post Throttle Body Charge Pipes * ECS Valved Exhaust system * Wagner Intercooler and Charge Pipes * APR HPFP with RS Injectors * Methanol Injection system with AEM Controller * CTS Transmission Mount Insert * Vossen HF5 20x9 with 265/30/20 Michelin PS4S
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by flee View Post
    ill record a video but there's nothing high pitch about the miltek resonated with catless.
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Quote Originally Posted by s4lorence View Post
    Hi all,
    If you're that particular about drone (and I am as well) - I would not purchase any exhaust that I had not ridden in personally....which I realize is not easy thing to do. But, drone is sooooo subjective and certainly cannot be appreciated by a video or a sound clip.
