Originally Posted by
outsider6661
I bought it from ECs back in 2013.
I attached some pictures. The passenger side front doesn't match the sweep/contour of the rear. It's a slight difference between the two
Sent from my SM-N975W using Tapatalk
Ahh.. i was just checking the other thread to compare your door blade to the other mismatched photo posted and it was you that posted that photo too!
Ok, so, this is a photo i just took (what i was talking about in the previous post #9 about physically comparing/test-fitting/interchanging all of my blades etc to the rs4) and all of the blades are identical, in all aspects physically, front and back, absolutely no differences in any way between the 3, and when on the car look identical and all of the lines match & sit flush/aligned etc.
The black and silver ones are from B6 a4s, the black one from my other car (removed maybe 10min before taking these photos), and the silver one i removed myself from another b6 a4 so as to have a full spare set, so can atest to those being 100% from a b6 a4 also.
I can definitely see a substantial enough difference in that front door blade in your photo compared to your rear one that it definitely doesnt match/look right.
In all honesty, it looks as if ECS may have sent you a 'b7' a4 door blade, as they are definitely slightly different to the b6 a4/b7 rs4.
could you take a photo of the part number on the rear of that blade and post... would love to have a definitive answer to all of this as all of my testing has 100% shown they (b6 a4 blades) are identical to b7 rs4 blades, have the same part numbers both on the blades themselves and in ETKA (OEM/dealer parts database), and fit perfectly on the rs4. You can see all 3 of my blades for yourself... i can post additional photos if you would like more comparison shots and part numbers, rears of the blades etc... all 3 identical.
