After I installed new parts, the car drove without problems for about 100 km, after which it gave P0087 again, too low pressure in the rail, an intermittent, sporadic problem. The pressures at the time of the error are apparently OK (see in the code at the end, where it gave too low pressure at 1.118 bar...). After turning the engine off and on, the limitation and warning light would disappear.
Besides that, in two mornings, in the cold, it gave too much pressure, the following days it didn't have any more issues).
I replaced the rail pressure sensor and the rail pressure regulator, to no good, same behavior. I reset the values learned from all sensors, rewrote the injectors (although they were the same, put in the same positions), to no good. I even tried putting the old pump pressure regulator on after cleaning it as best I could with brake spray and compressed air.
I also have an A4 2.7 that had a pump failure last year that had a similar behavior, but there it was losing fuel on the return of an injector. Here everything is clean, it doesn't lose a gram of diesel anywhere, I even changed the injector caps.
In fact, neither I nor my colleague with whom I did the work know what to do anymore. Maybe someone has encountered a similar problem and can give me an idea.
Code:
Tuesday,17,January,2023,18:32:09:00007 VCDS Version: Release 18.9.0 (x64) Running on Windows 10 x64 www.Ross-Tech.com Address 01: Engine Labels: 059-907-401-V1.clb Control Module Part Number: 8R0 907 401 J HW: 8K1 907 401 A Component and/or Version: 3.0TDI EDC17 H14 0008 Software Coding: 0114002C240F0928 Work Shop Code: WSC 36765 142 97888 ASAM Dataset: EV_ECM30TDI0118R0907401J 001008 (AU48) ROD: EV_ECM30TDI0118R0907401J.rod VCID: 39799BE5B8599582D2-806C 1 Fault Found: 5211 - Fuel Rail/System Pressure P0087 00 [167] - Too Low MIL ON - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 244419 km Date: 2023.01.17 Time: 18:05:12 Engine speed: 2195.00 /min Normed load value: 96.5 % Vehicle speed: 116 km/h Coolant temperature: 87 °C Intake air temperature: 28 °C Ambient air pressure: 990 mbar Voltage terminal 30: 14.240 V Unlearning counter according OBD: 80 Crankshaft speed (RPM): 2195.0 /min Vehicle speed: 115.46 km/h Mean injection quantity: 58.88 mg/stroke Fuel temperature: 40.4 °C Fuel high pressure: actual: 1.1189e+006 hPa Rail pressure regulation: status-Bits 0-7: 00000101 Inj Crv st Inj Char Act Val 0-Bits 0-7: 00010100 Readiness: N/A
