Results 1 to 3 of 3
    Junior Member Two Rings jamper's Avatar
    Mar 11 2018
    Roll bar for track use
    I'm looking for a roll bar/half cage for track use. I know Studio RSR makes a half cage but it's pricey. Curious what you guys are running in your cars. Thanks!
    '17 A3 Quattro * UM IS38 ECU, TCU, & Haldex tune, CasteSystems custom 3" catback, Öhlins R&T, SuperPro Engine Mounts, AP Racing brakes, Volk CE28
    Dec 07 2021
    Columbia, MD
    Have you looked in your area for a fabrication shop? Looks like there are a few in NJ. I would think a roll bar with a cross beam and points for a harness would be around 1200-1500.
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Unless you wear a helmet all the time, steel tubes in your car are more likely to end your life than save it. Further, a 1/2 cage is basically only helpful in a rollover which is super uncommon, and modern cars are much better in rollover protection than even 20 years ago. If you think you need a cage, I'd either 1. Re-evaluate your driving skill and suitability of a street car on the track and 2. consider buying a cheap dedicated track car with a full cage. Will be much cheaper to run and much better than nearly any street car.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
