Results 1 to 12 of 12
    Dec 04 2019
    Lexington Kentucky
    Clear Corner Lens
    Hi all,
    I am having a hard time tracking down the clear corner lens for my B7. If anyone knows where to source a pair I would be extremely grateful.
    Thanks in advance
    May 20 2010
    Contact / PM Phil fly300kts
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    https://www.vxtuning.com/product/aud...l-lenses-caps/
    Found these about a year ago.
    Is it only clear?
    Dec 04 2019
    Lexington Kentucky
    Quote Originally Posted by CrickiKaze View Post
    Is it only clear?
    Those aren't in stock and sent an email. Hoping to get a response tomorrow, but a little worried since its currently out of stock.
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    If you get the clear ones, Phil warned me that the plastic is more heat sensitive than the amber stock ones, so they can get a little melty. I drilled a small 3/16” hole in the bottom side (not the face) to allow some air movement. So far no problems, and the hole is invisible. Maybe it wasn’t necessary, but no sad saggy lenses! Just a note that Phil offered me about them.
    I'm still listening for that rattle!
    If it rattles, it's because I baby it.
    B7 S4 25Quattro
    Dec 04 2019
    Lexington Kentucky
    Quote Originally Posted by Zolli View Post
    Thank you. Just talked to Phil on email and have some getting made. Where exactly did you drill the hole? Can't picture where you drilled.
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    I don’t understand the image rotation of AZ, but this is a close-up of where I put the hole. The bottom is the right edge of the picture, and the top is on the left.
    You have to really look for it in person. Not sure how much or little it helps, but when things heat up, at least there’s a way for the hot air to escape
    B7 S4 25Quattro
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    The whole thing looks like this. The hole isn’t obvious at all
    B7 S4 25Quattro
    Dec 04 2019
    Lexington Kentucky
    I found it now. I wasn't sure if you were talking about on the actual lens of the headlight or the individual lens. Really excited for my clear corners to get done.
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Right right right - the hole is in the clear corner lens because it’s sealed tight.
    No hole in the outer main lens! No no no. Nonononono
    I did, however, drill some holes in the bottom of the headlight housing in these tubular sections that looked like they were supposed to have holes. That seems to have helped a ton with the condensation. Note that there are already openings in the bottom of the housing, I just added 2-3 more.
    B7 S4 25Quattro
    Established Member Two Rings Codiac's Avatar
    Apr 26 2011
    B7 S4
    I have a set I got from Phil years ago
    Dec 04 2019
    Lexington Kentucky
    Quote Originally Posted by Codiac View Post
    In the process of getting them made from phil.
