Our world renowned intercooler system now fits the 2019+ Audi Q3 with 8 Speed Auto!
The APR Intercooler System is a OEM-location upgrade that dramatically reduces intake air temperature (IAT), minimizes heat soak, and provides increased performance! The system is a direct bolt-on upgrade that requires no trimming and is recommended at every stage of performance. This system is based off our IC100019 upgrade which fits the 2015+ A3, S3, TT, TTS, Golf, Sportwagen, Alltrack, 22+ Arteon GTI, Golf R, and Jetta GLI, all with the 1.8T/2.0T EA888.3 and EA888.4 (Includes 8Y and MK8!)
Features:
Dramatically lowers intake air temp (IAT)
-- Increases horsepower while minimizing power-robbing heat soak!
-- Effectiveness tested to over 500 HP!
-- 21 horsepower gain over the factory system!
Massive core size
-- Use of the OEM-location allows for a massive intercooler core.
-- 24.25" x 16.25" x 1.25" - 492.5 in³ - OEM MK7 GTI (Similar to Tiguan/Q3)
-- 24.25" x 16.25" x 1.37" - 529.8 in³ - OEM MK7 Golf R (Similar to Arteon)
-- 24.00" x 16.25" x 2.25" - 877.5 in³ - APR
Intercooler installed in the best location for this platform
-- Utilizes factory air dams for exceptional airflow across the core.
-- 100% compatible with the Adaptive Cruise Control (ACC) system.
Highly effective core design
-- Bar-and-plate core with staggered and louvered fins.
-- Rigorous testing determined core style, fin density, and size.
-- Low pressure drop + highly effective cooling = high performance!
Smooth cast end tanks
-- Engineered for low turbulence/restriction and maximum flow.
-- Organically shaped to promote airflow across entire core.
-- Pressure tested to prevent power robbing boost leaks.
-- No hidden labor costs or permanent modifications
No trimming, cutting, or other costly modification required.
-- No modification to the Adaptive Cruise Control System required.
-- Full directions and APR world-renowned customer support included.
Designed by engineers with lasers
-- With the best equipment and smartest engineers, it just works!
Get all the Details, photos, and data here!
