Originally Posted by
vtraudt
fronts/upstream are both black?
Rears/downstream are green/blue?
Bosch 16287 for upstream it seams?
FWIW-
The Bosch 16287 has an approx 2-1/2 FT line length and is for both B1 and B2 front sensors and YES they are BLACK(male and female)
The BOSCH 16073 has a MUCH longer line length suitable for the rear locations. The female connectors for the rear sensors are BROWN and GREEN
The BROWN connector is for the left side(driver) rear sensor and the GREEN is for the right side---be advised that the male plug for the BROWN connector will need to be slightly modified--It's evident when you try to assemble...a few seconds with a Dremel tool an it will fit---I used a 1/4"OD drum sander.
When I was STAGE-II I still had all 4 O2 sensors in place and had to replace a defective rear sensor back in 2018 and changed them both....
