Front:
Audi Q5 3.0T Brembo 4 pot/piston calipers to use with 345mm rotors
They were cleaned and painted VHT blue, silver Audi Sport caliper decals added and high heat ceramic clear coated over.
Rear:
B6/7 S4 calipers and carriers to use with 310mm rotors
Disassembled, cleaned and put back together, new boots.
Painted VHT blue and high heat ceramic clear coated as well.
This is a direct bolt on and huge upgrade for C5 cars that have flimsy brakes from factory.
No modifications needed for these to work, the best, the most simple and effective brake upgrade for our old boats.
Benefits are better pedal modulation and significantly increased braking power, can't go wrong with this setup, perfectly balanced!
Set will come with front pad hardwarer.
No rotors or pads included in the sale. This is caliper set only.
I'll have to put crossover pipes back on I do have them, just not pictured. Set will be received ready to mount. I'm including brand new genuine Audi bolts for rear carriers.
I'll answer any questions you might have, just reach out.
Reason for sale is that I've got another set painted silver and I've decided to go with that instead of blue that was originally planned. (Pics of them at the end and they're not included in the sale with blue set)
Gone to a good home.
$1000 shipped.
