Hi, I'm running a 13 A4 with about 135,000 miles of mostly trouble-free cruising. Recently, the shifter suddenly stopped returning to its resting position near 3/4 when not in gear. It just seems to float and has no tension on it at all. It will shift through the gears, but finding the correct gear is quite difficult. I took the console apart and the shifter seems ok. looking under the hood, I can see the linkage move the and everything seems tight. Any ideas concerning what controls the tension on the shifter and guides it properly through the gears? Is it internal? Is there something in the linkage or shifter itself? Any help would be greatly appreciated as she does not enjoy life in the garage. thanks
