Results 1 to 3 of 3
    Junior Member One Ring
    Jan 16 2023
    Calgary
    Any rubbing or clearance issues with these rims?
    I’m currently looking at a used set of wheels and tires for a really good price, but not sure if there’s any fitment issues with the size.
    Rims are 22x10.5 +35 on 295/30/22
    Established Member Two Rings nerdybeard's Avatar
    Jan 17 2015
    B9 SQ5
    East Bay, CA
    What suspension mods are you running? Factory air or nah? From what I can tell, you're gonna be mega close to the front suspension. You'd wanna be prepared to run a 2-5mm spacer - which will add even more poke up front to already aggressive wheels. The rears will be fine most likely pending your ride height.
    Did you poke (no pun intended) around here as well? https://www.audizine.com/forum/showt...setup!/page139
    B9 SQ5 Navarra Prestige | 034 Stage 3+ TTE810, Wagner FMIC, CTS catted downpipe, 034 HPFP upgrade, 034 X34 Intake, 034 Inlet, 034 Trans insert, 034 ZTF-01 Forged 21x10 et32 + 5mm rear spacer, 295/35, CETE Module, Fuel-it, Maxton body kit,
    Past: B9 S5 Sportback, B8.5 S4, 4M Q7, B7 S4, B8.5 SQ5, mk4 R32, mk6 R, mk4 gti, '95 90 Quattro sport
    IG: @dom_quattro
    Jan 16 2023
    Calgary
    Quote Originally Posted by nerdybeard View Post
    Yea this thread should probably get deleted. I got helped out on that thread. My fault thinking it was just pictures in there before I posted this
