Results 1 to 6 of 6
    Established Member Two Rings vw754's Avatar
    Jan 18 2008
    stoke on trent
    Mag ride calibration
    Anyone able to calibrate Mag ride with vcds?
    If not what have you used,I've heard it makes a difference,I wanted to get mine done see if it does make a difference.
    Any one in Staffordshire can do it ?
    Junior Member Two Rings
    Oct 20 2021
    Pittsburgh
    It can only be done with the Dealer tool ,ODIS. Some Indy shops have the system/tool as well. If you are on Facebook, there is a guy in some of the groups that is based in the UK that can help out remotely or point you to a local shop. His name is Simon Leigh, it looks like his company is "Yorkshire/South Wales VAG Diagnostics"
    Dec 14 2021
    I researched to no avail a while back. I installed lowering springs and wanted to recalibrate. I wasn’t able to find an answer. It ended up settling nicely however. Good luck op
    Oct 20 2021
    Pittsburgh
    Edit: S3dan, the link below is to a thread from 2019, I'm not sure how much actual research or searching you did
    Quote Originally Posted by j_reid05 View Post
    Besides informing OP of the exact tool and a method for them being in the UK, here is a link to another thread that talks about it
    https://www.audizine.com/forum/showt...owering-please
    May 29 2021
    Socal
    what type of difference do you feel?
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
