Originally Posted by
MongoMcG
Looks like you have the garage for it and the skills, since you did it once. I went through the procedure in the FSM and watched a couple of vid's - not for the faint of heart. I am curious: how well did the transmission jack handle the 6MT, esp. stability and safety? A new clutch is on my list, but haven't decided if I want to take it on myself.
Speaking of Mustang transmissions, I still have the original AODE (essentially a 4R70) trans in the SN95 Mustang (72K Miles). I was going to mash it until it broke and replace with a Tremec, but it refuses to break. Surprisingly strong transmission (516 ft lb) paired up with the 3.8L V6, from which I built a 4.2L stroker, supercharged, cammed, gasket match ported & polished, upgraded the intake to the high flowing Windstar (minivan!) intake, and more. Fast enough, and torque-y as heck, but def not a corner carver. If I am ever going to make competitive autocross times in the Mustang it needs a Cobra rear end for the IRS and the 3.73 gear. Gotta' finish this B8 build because it interrupted the Mustang project, which is completely stripped and hanging on the rotisserie since last spring waiting for a final media blast and POR-15 coating on the bottom. It should be quite somethin' when done again, especially if I can find a deal on that Cobra rear end.
It's really not that bad....it's just a lot of disassembly. Believe it or not, my transmission jack is a Harbor Freight low lift unit (800 lb rating) and it worked really well. The platform is adjustable in all four directions and the thing is solid as a rock. As you can see in the picture, I used two straps to hold it since I was doing the job myself. And once I had it on the jack, I never took it off. I just replaced the entire clutch with the transmission still on the jack.
FWIW, one of the main reasons that I decided to replace the clutch myself is because I don't like other people working on my vehicles. Ever. I used to work as a dealership technician back in the day, so I know that guys take shortcuts all the time. Some of them are total hacks. When I work on my vehicles, it's by the book. Every bolt is torqued to spec. Every stretch bolt is replaced. I purchased the factory specified lubes (I think there were three of them). Every step is done by the book. Maybe I'm a little anal, but that's okay...I know the job is done right. Kind of ironic that I'm already having an issue and if it's related to something as simple as an Input Shaft Seal, then that's my own stupid mistake and I'll have to do the entire job over again.
BTW, if you don't have any kind of lift, the job can be done on jackstands. But I'm not 100% sure if you can get the transmission out from under the car on jackstands unless they are pretty high. I think I remember reading somewhere that you need 18" of clearance or something like that to get the transmission out from under the car. If not, you can still do the clutch job with the transmission under the car, but that would be a major pain in the ass and I wouldn't recommend it.
As far as your Mustang, yeah....I've heard those are pretty tough transmissions. And as much as I'm a manual transmission guy, I think those new 10-speed automatics they are using now are a lot of fun My buddy has one and I've ripped on it a few times. It was a blast.
