Results 1 to 9 of 9
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Deep snow then "Sport Differential: system fault"
    Did some searching but only found one or two posts about this.
    On Friday went through some deep snow a couple of times on my way to work and the car was fine (as usual).
    But later in the afternoon I went to run an errand and after starting the car it shook semi strong and shut off.
    Second attempt got the same result.
    Third attempt it started but got the "Sport Differential: system fault" but the car was idling fine.
    Drove down the street and the car shut off (while in motion) then turned back on so I turned around and went back to the office with thoughts of getting a tow to my local Indy shop (Almost Racing).
    But after I got back to the office I thought I would attempt one more start and luckily it started totally fine with no errors.
    Ran my errands and the car has been fine ever since.
    Pulled a ton of codes (using VagCom) but after clearing them none have come back.
    Has this happened to others?
    Thx
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Senior Member Four Rings
    Jun 08 2021
    PA
    I would check all connections and plugs for water intrusion. That’s the first thing that comes to mind
    Junior Member Two Rings rovision's Avatar
    Aug 06 2008
    2013 S4 SD, B&O +++ 2015 A3 SP Q
    Ca
    I find it always useful to save codes after malfunctions. Sometimes I also sort them by time of occurrence to better understand the succession of events that lead to a malfunction.
    Just reseting DTC's will not "fix" the issue, if there's one.
    Mar 12 2010
    Yes I did save the codes. Always do.
    6173 Fuel Pump
    8931 Secondary Air Injection Bank 1 P0491 Insufficient Flow
    8932 Secondary Air Injection Bank 2 P0492 Insufficient Flow
    1324 Control Module for All Wheel Drive (J492)
    Aug 06 2008
    Ca
    I'd suggest to take a look at this: http://wiki.ross-tech.com/wiki/index.php/P0491
    Veteran Member Three Rings Krusty's Avatar
    Sep 18 2012
    long beach
    Has happened to me and they never came back.
    2011 sprint blue s4, EC subframe stabilizer, ECS short shifter, Euro Impulse weighted shift knob, custom air intake, RS grille, CR-15, 034 rear diff mounts/rear diff carrier mount inserts, Apikol rear diff mount insert, 10mm(f)/12mm(r), ECS strut tower brace, ECS front adjustable end links.
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    The only code related to the sport diff is the J492. The secondary air issues are a common, unrelated code.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Mar 12 2010
    Yes agreed.
    And the more I look into this the more I feel it was the snow getting into the wrong place.
    I'll be at the dealer on Thursday for an unrelated issue and ask them to take a close look....
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I wouldn't worry about it..... Has happened to me a few times - I bet it's snow messing with a sensor - just had my diff fluid changed and the shop found no issues at all.
    I've had ABS lights pop up in my Subaru due to snow - white stuff sticks to odd sensors - but sure is fun to drive in!
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
