hellou,
I've got fault codes for my Audi S6 facelift - intake manifold flap stuck for bank 1 and 2. Is it problem with swirl flaps or solenoid that controls flaps or vacuum actuator or pressure leak?
Also on dashboard is fault that I cannot exceed 4000 rpm. First time it happend about 10days ago, I changed battery (was almost dead) after that it was ok for 2 days, but then again "max 4000rpm". Now 1 from 5 times I drive the car there is no fault (sometimes I can drive without any issues, but a lot of times fault code).
10152 - Intake Manifold Flap; Bank 2
P2005 00 [096] - Stuck Open
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 143835 km
Date: 2020.07.16
Time: 22:17:09
Engine speed: 1085.00 /min
Normed load value: 7.5 %
Vehicle speed: 15 km/h
Coolant temperature: 102 °C
Intake air temperature: 58 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 14.112 V
Unlearning counter according OBD: 35
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
10153 - Intake Manifold Flap; Bank 2
P2007 00 [101] - Stuck Closed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 143881 km
Date: 2020.07.17
Time: 07:06:12
Engine speed: 1653.50 /min
Normed load value: 34.9 %
Vehicle speed: 24 km/h
Coolant temperature: 100 °C
Intake air temperature: 42 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 14.017 V
Unlearning counter according OBD: 40
8993 - Intake Manifold Flap; Bank 2
P2007 00 [096] - Stuck Closed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 143780 km
Date: 2020.07.16
Time: 14:59:33
Engine speed: 651.00 /min
Normed load value: 6.7 %
Vehicle speed: 0 km/h
Coolant temperature: 104 °C
Intake air temperature: 56 °C
Voltage terminal 30: 14.041 V
Unlearning counter according OBD: 34
2978 - Intake Manifold Flap; Bank 1
P2006 00 [096] - Stuck Closed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 143780 km
Date: 2020.07.16
Time: 14:59:33
10151 - Intake Manifold Flap; Bank 1
P2006 00 [101] - Stuck Closed
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 143835 km
Date: 2020.07.16
Time: 22:17:09
