Results 1 to 10 of 10
    Junior Member Two Rings
    Feb 05 2021
    Florida
    Short term fuel trim question
    Is it normal for your stft to zero out under WOT?
    I had a b7 a4 that would show the corrections at WOT
    all the way through the rpm range. I figured the b5 s4 would do the same.
    May 10 2018
    MA
    Fuel trims aren’t used at WOT
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Narrowband O2s don't know what's going on at WOT.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Feb 05 2021
    Florida
    So how does the ecu know if it's going lean or not? EGT'S?
    or maybe knock sensors?
    May 10 2018
    MA
    Quote Originally Posted by JT-A4B7 View Post
    Correct. If your egts are working and not tuned out (many of us do, and run a wideband or 2), allows for fuel corrects in both open and closed loop.
    Feb 23 2010
    Emmaus Pa
    IMO, if you have anything other than a cookie cutter stage 1/2 tune, a wideband gauge is an absolute must.
    B9 S4- EPL/AWE
    May 10 2018
    MA
    Quote Originally Posted by CELison View Post
    Absolutely agree
    Feb 05 2021
    Florida
    Can the wide band be connected to the ecu?
    Feb 23 2010
    Emmaus Pa
    It can for logging by tapping into a rear 02 plug you're not using. But as far as I know, nobody is able to use it to adjust fueling at WOT in real time. Maybe Philadot? Not sure.
    B9 S4- EPL/AWE
    May 10 2018
    MA
    Also important to note, the car doesn’t use STFT/LTFT in the traditional sense. It shows idle trim (1/3 in block 32), and cruising/light throttle (2/4 or block 32). This is because it’s a torque based egt mgmt setup.
