Hi All, my engine is out for a clutch, new turbos, and gaskets, etc... Taking the hard pipe coolant & aux-after-run pump off. I am seeing traces of oil in the coolant. However, when draining the radiator the coolant is pink without traces of oil. There was no trace of oil in the coolant turbo feed as it drained either. From the pictures, milky fluid is in the upper engine only.
Any ideas? before I replace the head gaskets & oil cooler. I will remove oil pan later this week to check the crankcase components.
I am thinking it is an early head gasket failure possibly exhaust gas leakage. A cylinder compress test before the engine out was five cylinders in the mid 170s and one low 160s.
Any ideas, I appreciate your thoughts. Attachment 293373Attachment 293374Attachment 293375Attachment 293376
Sent from my motorola one zoom using Audizine Forum mobile app
