New bright D3S/D1S LEDs for your projectors - CLEAN WHITE 5500K Color Temperature! This gives a higher-end upgraded look to your low beams compared to stock yellow halogen while still having the visibility you expect!
20% off for limited time – get it when you can:
“D20”
Bright - NO ERRORS - PLUG & PLAY - NO special ballasts adapters or plugs required!
Listing:
https://deautokey.com/product/d3s-le...e-to-d3s-xenon
This new diode technology that competes with the xenon brightness and have been tested thoroughly in all Audi/VW housings to ensure you are only getting the best lighting for your car!
-Plug & Play
-NO errors
-Clean White color temp no blue or yellow tint
-NO special wires, plugs or ballasts required – simple use with your OEM setup
-Simple install: Remove your xenon bulbs and replace with our LEDs & you are ready to go!
-Quick light-up time instant ON
-No warm-up time required
-Clean cut-off in your projectors due to a smarter diode alignment and clean beam PCB board
