Results 1 to 3 of 3
    Established Member Two Rings Dwightlud's Avatar
    Jan 08 2016
    2006 A4 Avant
    Eagan, MN
    Bad Control Module?
    I am working on a friends 2006 A6 sedan and have run across a strange electrical issue. When I first start and drive the car, the left rear turn signal works fine. After a short while it quits. If I shut off the car and let it rest for a half hour or so, the turn signal will work again, but only for a short time. My searching on the problem brought up the subject of a power control module that may be the culprit. Where would this be located?
    Oct 16 2021
    2010 A6 3.0T Prestige
    Gallitzin
    So I also have this problem even with the LED lights on my 2010. I think the issue is corroded light connector or a bad ground because the lights still function but the dash says that they are "blown."
    Jun 28 2019
    Wattsburg, Pa
    Older thread.... but need to replace the light assembly. Known issue.
    Sent from my SM-S918U using Audizine Forum mobile app
