Results 1 to 7 of 7
    Feb 19 2013
    Bay Area, California
    Practical Diff Upgrade options for my B6
    Probably not a new topic, but the search wasn’t coming up with anything so here goes:
    What practical options are there for fixing the incredibly annoying diff clunk? I love my ol’ B6, but if there is one thing i could change its the clunk when you need to change quickly from a lift to back on the gas. Reliability is key, as i drive this car all the time, including in lovely bay area traffic.
    Jan 29 2017
    B7 RS4, B15 Sentra Spec V
    San Antonio, TX
    New bushing, either an assembly or the bushing alone but would need a way to press it out. I'm referring to after market though and would need to look for anything under 80 durometer. You could possible to OEM.
    Senior Member Three Rings Rerb's Avatar
    Sep 08 2021
    2016 Honda CR-V, 1999 Suzuki Bandit 1200 Turbo
    Maine
    I have this (or something similar) - It wasn't my diff. I did the ECS diff mount and center carrier bearing insert, and if anything the clunk got worse. Your clunk could be the diff, but mine seems to be coming from the trans/clutch area.
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Rerb do you still have an OEM Dual mass flywheel? If not, single mass flywheels have been known to occasion some trans noise.
    Old Geezer, formerly known as Stud Muffin
    Jan 29 2017
    San Antonio, TX
    Any other clunk might be the carrier bearing unless the shafts are worn, assuming hardware has been looked over.
    May 29 2010
    2004 Audi S4, 2008 Audi RS4 Ti
    Phildelphia / Auckland
    The clunk is probably the backlash on the ring and pinion too loose.
    Need to find a shim or stackable shims to lash it tighter.
    Oddly enough, I had two RS4 rear diffs end up with significant backlash. Both whine a little as well.
    Haven’t had time to remove the existing shims, measure diameter and thickness, and have a variety of thicknesses machined or maybe I can find an OTS equivalent.
    Sep 08 2021
    Maine
    Quote Originally Posted by S4Bennett View Post
    This makes sense, I still have the dual mass flywheel and significant diff whine between 40 - 50 and 90 - 100. How do you measure backlash?
