The picture in the link is the harness, I'd work from that picture to identify the plug.
Grommet 13 >
one plug 26 connects to the injectors harness >
one plug 28 3-pin to the left bank knock sensor >
two plug 31 2-pin protruding center >
three plug 34 to the coils and one plug 23 3-pin opposite them >
two plug 18 2-pin, one to the A/C, one to motor mount? >
long run (the 41 section to the injectors does not exist on this harness; they are run by a separate harness off plug 26) >
one plug 24, either 3-pin to the oil level sensor or 2-pin to the intake manifold flap actuator >
one plug 23 3-pin
But notice the part list says plug 19 should be the 2-pin orange plugs for the motor mounts, and plug 19 would be the black/violet 2-pin to the steering rack servotronic. Maybe one of the pair of 18s should been marked 19, as we only see one 19 on the diagram?
So if plug 24 and plug 23 are at the end of a long run that took them to the bottom of the engine, I'd guess 24 is the 3-pin plug to the oil level sensor on the bottom of the oil pan. Then 23, from the listed applications, would likely be the engine speed sensor.
Asked before and got "please I don't really want to be helped" response. What's the engine code? How about a picture? Are you working from having a harness plug you don't know where to put, or a device plug you don't know where the harness plug is for? Why do you claim it's "facing upward"?
