Results 1 to 4 of 4
    Senior Member Three Rings Ryanhouck9's Avatar
    Apr 10 2022
    X3 m40i
    Free Partial eventuri intakes rs5 red 13-15
    Hey guys I have a incomplete set of eventuri intakes , they’re for a 13-15 RS5 and they’re a very early production set. I have the carbon arms, carbon air scoops I think they’re called? And the carbon filter holders. The missing pieces are the filters, the clamps to hold the filters into the intakes and the mounting plates to keep the intakes up.
    They have yellowed a bit over time especially the carbon arms… I experimented with just the arms and started to get the clear coat off im sure if you have the skills to work with the carbon you can refinish them nicely. I was boiling the carbon arms in hot water and it was making the clear coat peel off. They look ugly and need the process finished to look good again. But I don’t have any time to mess around with them anymore. Figured someone else would make it a cool project if they know what they’re doing.
    Pay the shipping cost and you can have them! First come first serve , and you have to have an b8.5 rs5, won’t give them to you unless you do ;) thanks!
    Apr 10 2022
    X3 m40i
    They’re “sold”!
    Mar 15 2017
    Austin TX
    To the "buyer", its worth contacting Bilal at Eventuri as they were offering a free exchange on the red and blue ones for quite awhile due to the premature yellowing and may still. I had a full red kit and they all yellowed so I got a FULL black kit for free from them and they even sent me prepaid postage boxes for the return along with the replacements. The original factory they used to produce them didnt use a good enough high-heat epoxy which caused them to all yellow quite quickly but now they are on their 3rd-gen factory that makes the Black versions only that don't yellow. Just fyi but its worth a shot and Eventuri provides TOP NOTCH customer service - ask for Bilal if he is still there and you give it a try.
    Junior Member Two Rings
    May 01 2019
    Nashville, TN
    I would like these
