Results 1 to 7 of 7
    Sep 13 2015
    Hell City, Az.
    Audi A6 - 20" Rotor Wheel with 275/35 tire fitment
    Updated with wheel specs!
    Hello,
    I am trying to purchase some new wheels, I just got my Audi A6 with 18" wheels. But before I make the purchase, I wanted to check to see if there were any concerns with fitment? I dont think I saw anything that would be an issue, but I rather verify before I pull the plug.
    These wheels come with Brand new Goodyear Eagle Exhilarate M+S (Mud + Snow) tires. 275/35 ZR20.
    They are the rotor style Audi wheels.
    Here are the specs: 9Jx20H2ET26 from the back of the wheel itself
    thank you!
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    You didn't give us the wheel specs...
    18 S6
    Feb 15 2011
    Northern VA
    Ideally you want 275/30 fitment for 20" wheels..
    Veteran Member Three Rings MTV10's Avatar
    Apr 29 2020
    Montreal
    Those are OEM RS5 rotors. They will fit. Are you lowered significantly? If so, you'll need to camber out the rear to avoid rubbing. Stock ride height will be fine.
    Photos of these exact wheels on my car.
    2018 /S6 | Mythos Black / Arras Red | Stage II ECU | APR TCU | ARM Downpipes | AWE Touring Exhaust | SRM Intakes | CETE Lowering Module | 034M DSG Mount Insert | HRE P43SC
    Sep 16 2020
    West Michigan
    I run a 285/30/21 on OEM RS7 21x9 wheels. No problem.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Established Member Two Rings OhioS6's Avatar
    May 19 2022
    Ohio
    I got TSW Nurburgring wheels 20x10 ET +40 also no issues, 15’ S6
    Junior Member Two Rings Dave4501's Avatar
    Dec 11 2018
    2014 A7
    Chattanooga, TN
    I have 275/35/20 tires on my A7 with stock wheels. It came with 265/35/20 tires as OEM.
    I'm glad I don't have 30 aspect as it would give me less sidewall for bumps.
