Results 1 to 25 of 25
Thread: RNSE Whoas
    Established Member Two Rings 09SCiduA's Avatar
    Jan 24 2010
    1990 Audi Coupe Quattro S2 Clone
    Bozeman, MT
    RNSE Whoas
    I recently got a nice RNSE head unit and though it appears to be in excellent condition, after using an adapter harness acquired off ebay, it doesn't even try to boot up...I hear, very softly, something turning on...maybe the CD player laser but nothing else...I've double checked all the connections but no forward progress....is there any way to repair or use this unit or is this just part of using old German stuff...sometimes it's amazing and sometimes not...?
    Any help or suggestions will be greatly appreciated!
    Jan 24 2010
    Paramus,NJ USA
    Did you check the 15amp fuse on the back of the unit??
    Ziddy Autowerks
    Jan 24 2010
    Bozeman, MT
    I did and it looks good...but perhaps I'll swap it out for safe measures...
    Sent from my SM-G991U using Tapatalk
    2004 A4 Avant 1.8t 6spd, S4 RSB, 2.0 coil packs, SAIP delete, Bosch 550s, Mountune stg 1.5
    Jan 24 2010
    Paramus,NJ USA
    Are you sure the harness you have matches the radio? Fuse in the car is good?
    Ziddy Autowerks
    Jan 24 2010
    Bozeman, MT
    https://www.ebay.com/itm/165029262034
    This is the harness I thought I researched and used...everything, wires amd all, appeared to sync to where they were needed...I followed the Symphony II to RNSE writeup in the stickies... I'll replace the 15A fuse on neck of receiver to eliminate that an issue...
    Jan 24 2010
    Paramus,NJ USA
    IS THE FUSE IN THE CAR GOOD?
    Ziddy Autowerks
    Jan 24 2010
    Bozeman, MT
    I also checked the radio fuse...it's good too...I swapped back to the Symphony II and everything works as it should...argh! Is there any place that can "repair" or check things out?
    Jan 24 2010
    Paramus,NJ USA
    IF the stock unit works, I would assume your issue is with the new unit or the adapter harness.
    Ziddy Autowerks
    Veteran Member Four Rings Gunnarrrrr's Avatar
    Mar 25 2015
    cars, wheels, cars with wheels
    Placer County
    If you hear it turning on, my guess is the display cable
    B9 SQ5 Mythos X Magma - 034 stg2
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jan 24 2010
    Bozeman, MT
    Thanks for the suggestions...I suppose it is mildly obvious. I'll check out the wiring et Al and will report back.
    Sep 16 2010
    Central Wash
    FWIW you can hook it up and work on it on the bench. It does not need to be installed in the car. Connect V+ / V- power properly and you can troubleshoot it outside of the car- even enter the code.
    I have a spare one, probably cables and parts and everything if you get any cues to what's up with it and need anything. Tons of videos on youtube or out on the web about how to troubleshoot it. If you have ever tinkered with electronics they're not very technical. But if it's stone cold and not connected to power they typically make some robot noises when you plug them in and the DVD head resets and aligns.
    There are also a couple harness's ; Bose or NON-Bose are slightly different, and not uncommon for some cheap ones to show up wired wrong.
    Mar 25 2015
    Placer County
    RNSE Whoas
    if it helps at all, it’s (in my case) the yellow wire (+) and the brown wire (-)
    Also, there’s an amazon seller selling the display cables for the same price as aliexpress & ebay now, with prime shipping.
    https://a.co/d/55teGs9
    You motivated me to troubleshoot my other RNSE. here’s a couple tricks I found.
    the display tray open button should work without a display. Sometimes idk. I wouldn’t rely on this. Same with the fan, not really a consistent indicator. if you pull the display open by hand (has to be disconnected from power or it won’t move) even just a little bit, it will retract as soon as power is connected. Also, the dvd reader turns on as soon as it gets power. Stick a zip tie or something through the slot and see if you hear it hit the spinning navigation disk.
    These just helped me find the issue. It’s once again, a display cable. It’s always the display cable smh.
    I ended up swapping a cable from one of my other RNSE’s laying around and confirmed it.
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jan 24 2010
    Bozeman, MT
    This is excellent! Thank you for the suggestions @rollerton & @Gunnarrrrr !
    I'm going to see if I can trouble shoot on the bench and then confirm wiring/pins on the harness adapter...
    Jan 24 2010
    Bozeman, MT
    For verification, could you (one of you) snap a photo of the harness as it interfaces into the head unit? The big, locking harness into the back of the RNSE...please?!
    Mar 25 2015
    Placer County
    RNSE Whoas
    Quote Originally Posted by 09SCiduA View Post
    It’s called a quadlock btw
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Sep 16 2010
    Central Wash
    FWIW the bottom two parts of that connector are for sounds/ data stuff and aren't needed for general troubleshooting. There's a diagram on the head unit that shows which connections are which. To get it to boot up and test functionality generally just need power/ ground.
    Jan 24 2010
    Bozeman, MT
    Quadlock, got it! Thank you for the photos and I just found the sticker with the wire functions/routing... looked like it peeled off on my workbench... thanks again!!
    Jan 24 2010
    Bozeman, MT
    I ran the bench test and connected the Yellow wire to positive and the Brown to ground and I got nothing; the headunit doesn't flash, turn on and I didn't hear anything either this time...I'm thinking the unit is crap...BUT, I haven't swapped out the 15A fuse in the back of the unit so as though it looks good, I'll swap that out for confirmation...
    Veteran Member Three Rings Puddin Tane's Avatar
    Jun 22 2020
    Athens, GA
    Quote Originally Posted by Gunnarrrrr View Post
    It’s called a quadlock btw...
    What on earth did you use to take those pictures??
    Mar 25 2015
    Placer County
    Quote Originally Posted by Puddin Tane View Post
    an iPhone
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jan 24 2010
    Bozeman, MT
    The photos show well on my end and I'm grateful for how clear they are! Thank you!
    Here's my harness adapter:
    I marked the pin terminals in white for the bench test...
    Mar 25 2015
    Placer County
    You got the right pins. So if you still got nothing, idk what to tell ya. If your unit is busted I’m about to put another one up for sale
    2005 B6 GT2871
    2005 B6 S4 4.2L 6MT
    Jan 24 2010
    Paramus,NJ USA
    If you want to sell the non working unit let me know.
    Ziddy Autowerks
    Jan 24 2010
    Bozeman, MT
    I'll swap the fuse tonight and try again...I will let both of you know soon!
    Jan 09 2012
    MA
    is it soon yet, lol
    sorry couldn't help it :)
