Special part hunt requests are welcome but become more and more difficult for the B5.
1. cluster mph, "old style" inlay (can be swapped). Digital clock, big DIS, log-in code included. $279
2. rear upper control arms w/ all bushings, sheet metal version. $185 /pair
3. rear diff bracket w/ bushings. $78
4. sprocket for 2.7T engines. $60
5. cooling hardline, engine front side. $65 (8 pcs. untill NLA!)
6. lower radiator water hose "rev. -AQ". $70
7. signal switch. $68
8. switch /w cruise control. $132
9. wastegate control lines (formally A6/allroad, "AA"+"AB"). $230
10. turbo oil return lines. $280/both
11. y-hose. $28
12. timing belt sheet metal rear cover. Only this side available $48
13. RS4 rear subframe bushings (2+2), stiffer than S4 ones. $262/2+2
14. water deflector set, used, 100.00% perfect condition in all terms, one set only! SOLD
15. cross bar for front subframe $65
16. engine cover set (repost), red logo. $160/3pcs.
17. RS4 brake booster. Bigger dia. than S4 ones. Same connections $168
18. S4 front fenderliners (repost). $140/pair
19. S4 Intercooler air ducts. $109/pair
20. Avant onyx trunk side covers, used, 100.00% perfect condition in all terms, one set only. Rare find! SOLD
21. Valeo ecodes. D2S xenon, clear corners. Please inquire.
-Jens
