Results 1 to 20 of 20
    Jul 17 2022
    Kansas
    Do you rotate tires?
    I have a 2017 A4 Quattro. I bought it with 40k miles and now has 55k after a year and a half of my ownership. This morning I decided to rotate tires. On the passenger side I could not tell a difference in wear levels between front and back. On the driver side the front was slightly more worn. This is just me eyeballing it, I don’t have a tread gauge.
    So it got me thinking, do you guys rotate tires or have you seen uniform wear on this platform? I know it’s always a good idea, but just curious to hear from someone with more observed miles than me.
    Senior Member Two Rings AccordingToAlex's Avatar
    Oct 04 2019
    SF Bay Area
    Yes, you should always rotate tires, especially on Quattro cars. Each corner will wear differently so you want to keep the wear even across all 4 tires. If there's a difference in tread depth that's greater than 4/32" , you'll fry the Quattro.
    Jan 01 2018
    2021 Q5; 2003 F250
    Southeast PA
    Yes, I used to do it every 5k miles. But now I only go about 10k a year, so I rotate when I change to the winters and vice versa.
    Sent from my SM-G981V using Audizine Forum mobile app
    Jun 24 2020
    Somewhere
    if you want your tire mileage warranty to stay good then yes. usually it's somewhere around 5k miles
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Quote Originally Posted by AccordingToAlex View Post
    100% right there.
    What's hilarious is most dealers say there's no need to rotate on the Quattro LMAO
    Standard would be every 10k but if you drive it hard and really carve corners better to move that up to every 5k and really keep the wear even. Plus, the real important reason is to put eyes on the tire. Track uneven wear, heck I once caught a sidewall bubble on the INNER sidewall at a rotation.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I'll wait for the explanation as to how its going to "fry the quattro".
    2019 Audi A4 Quattro Premium Plus | Manhattan Gray | APR Stage 1 | ECS Intercooler Kit
    *goodbye sweet prince* 2009 Audi A4 Quattro Premium | Ibis White | CTS K04 Hybrid | 034 Motorsports HFC | REV9 Intercooler | Ward Performance Tuning
    Visit us on FB @ Audi B9-B9.5 A4 Owners Official Group
    Oct 04 2019
    SF Bay Area
    Quote Originally Posted by Spawne32 View Post
    When tread depths differ too much, it essentially makes your wheels different sizes. This puts your center differential into a frenzy, as it tries to compensate for the different rotational speeds, even in a straight line. This constant correction overheats the diff and boom, diff goes bye-bye.
    Nov 20 2016
    You do understand that the center differential was designed to constantly be in motion to correct for sublte variations in traction on all wheels, correct? If your statement was correct, people who drive these cars in almost constant winter conditions, especially in other countries would smoke their center differentials in a matter of no time as no particular wheel in their weather conditions would ever have the same level of traction.
    Oct 04 2019
    SF Bay Area
    I suggest doing more research on how differentials work. To each their own though ¯\_(ツ)_/¯
    Nov 20 2016
    lol I know how differentials work. Audi is not so stupid as to design a system that cannot tolerate differences in tire tread depth. Trust me on that. People abuse the quattro system far worse than tire wear and you'd be amazed at how strong it is.
    Jul 16 2018
    Atlanta
    Audi has always quoted to not exceed a front axle average tread depth vs rear axle average tread depth difference of 2mm for longitudinal (Torsen) or 3mm for transverse (Haldex). For Torsen, this represents roughly a 0.6% difference limit
    I'm sure the Torsen center diff being in a constant state of lock will do it no favors. A post from a quick google search: https://www.motorgeek.com/threads/di...0/#post-555733 Though that example is more extreme, with somewhere around 1% front vs rear output shaft speed difference.
    Basically, the Torsen can accommodate differing output shaft rpms, but it tries to fight that, that's the purpose. If the differing speeds are significant and forced full time, the internal gears longevity is trashed. I do wonder how the revised PAT variant compares to the planetary gear variant for output difference tolerance, if they differ at all.
    Differing individual wheels speeds is the job of the open diffs on the axles, and the ESP system utilizing the brakes. I do wonder too if too much wheel speed difference would be flagged by the ESP system as "something is wrong" and cause it to fight to try and stabilize the wheel speeds at a common value, which would likely just wear out the brakes.
    Jul 16 2018
    Atlanta
    As to the OP question, of course. Tires should always be rotated front<>rear at least on some cycle. My current tires are directional, so I get no left<>right balancing. You can't do real inner<>outer balancing without dismounting and remounting the tires. At least not till we get 0 offset reversable wheels. :-) Actually, I wonder if you could do that with 3-piece wheels, if any are designed to allow mounting to the rim from either side.
    I do rotations every ~6k. As my tires normally last 22-25k, that means it's running towards the end of having tires on front and back twice. While I don't get the substantial center wear on the rear axle like my old G35, the extra shoulder wear on the front axle is as obvious as any other car.
    Nov 20 2016
    Quote Originally Posted by Smac770 View Post
    Torsen on the center diff was done away with after 09 was it not?
    Jul 16 2018
    Atlanta
    No, Torsen is still the center diff even today, except for transverse VW clones using Haldex and quattro ultra using that Haldex clone system they made. The original 50:50 design (type A) usage ended around that time, but the PAT (type B) Gen2 and planetary (type C) asymmetric configs are alive and well.
    Nov 20 2016
    So what ever happened to the crown wheel center differential that supposedly came on anything past 09 for the B8's?
    Jul 16 2018
    Atlanta
    Crown diff was only ever on type 0B5 DL501-7Q transmissions, only on some early RoW Q5 and allroads, and on all RS4/RS5 automatic models. Crown diff is dead as of the end of B8.5 RS4/RS5.
    Nov 20 2016
    Interesting, if I recall there was a really big thread in the B8 forum regarding the changes to the center differential. I always thought that the torsen was discontinued after model year 09 and was the reason for the change in the driveshaft couplings on later models.
    Jul 16 2018
    Atlanta
    Yeah, I made that 10 page PowerPoint detailing the history, in that thread where someone was sure the center diff in their B8.5 S4 was a crown diff.
    Jan 23 2014
    '13 Touareg TDI - '08 RS4 Mug/Ti
    Derby City
    That is a false statement.
    Oct 04 2019
    SF Bay Area
    Quote Originally Posted by 87vr6 View Post
    Okay I'll let Audi know.
