Results 1 to 13 of 13
    Veteran Member Three Rings bwdysart's Avatar
    Sep 05 2017
    B7_A4
    Richmond VA
    Passenger mirror reverse tilt gone
    I kind of just noticed that my passenger mirror doesn’t tilt down anymore. It did when I got the car. Where do I start to fix that? VCDS does not show any codes that seem related to that.
    I did replace my front seats with B8.5 S4 seats so whatever modules were in the seats are gone. Did those modules control the mirror tilting down? I can’t remember if it stopped tilting down immediately after I put the seats in or not.
    I would just leave this alone but since I parallel park every day in the city I do miss having that
    May 20 2010
    Dumb question, but you do have the mirror switch flipped to the passenger side, right?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Sep 05 2017
    B7_A4
    Richmond VA
    Never a dumb question diagnosing weird issues. Yes I’ve got it set to passenger and I’ve tried all positions
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    I picked up an Avant really cheap a few years ago that had a bunch of issues and have been getting them sorted little by little.
    When I bought it, the mirrors folded in, but the tilt down when you put it in reverse did not work. I pulled the mirror and checked the pins from the door harness to the mirror and found that I got voltage when the mirror was supposed to tilt, so I figured it had to be the mirror motor.
    I grabbed the P/N off the motor and hit the pick and pull looking for motors with the same P/N. What was strange was that I found the correct part number in a drivers side mirror. I am guessing it is a mirror motor with tilt and memory that is the key and goes on both sides. The junk yard mirror motor fixed the tilt feature.
    Anyway, I would start by checking for voltage at the mirror motor connector when you put it in reverse. I cannot really say if the seat swap will have any connection to the mirror tilt not working.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Senior Member Two Rings PhireSideZA's Avatar
    Dec 31 2021
    Ryobi Lawnmower, 1hp
    South Africa
    Does the tilt feature not depend on the module that is associated with the power adjust seats? I seem to recall that they are somehow linked
    Feb 15 2016
    Cambridge,Ontario
    I didn't even realize b7 had that feature.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    wow fun thread, this morning on FB someone posted this exact 'reversed' question because he found this feature annoying and useless... hahah
    Is it like the key fob? when you loose power it need to be 'resync' and then its back ?
    very useful imo when you have expensive wheels, and the local law request a parking less than 30cm, but I want 5cm to be sure no car will hit my mirrors
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    I've got B8 S4 seats as well, shouldn't affect the mirror but who knows. I can check that it still works when I get off work.
    Side conversation someone might have thoughts on, I think my only complaint is it really sucks at reverting to the memory position after being used. IIRC is overshoots and more points toward the sky vs where it should be set.
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    Reversing Mirror tilt and power folding mirrors was part of the Memory Seats package for me.
    Current:
    2017 B9 A4 Technik, 2.0T, 6 spd manual, S-Line, quattro with Ultra
    2008 B7 A4 Avant, 2.0T, 6MTQS, S-Line, Special Edition
    Past: - 2005 B6 A4 3.0 V6 6MTQS, 1998 B5 A4 2.8 V6 5MTQS
    Jan 14 2015
    South Dakota
    So tested mine, it doesn't work either. You might be able to confirm with VCDS, but when I did my 2.7 swap, I did the seats at the same time. I've had an error since for DTC memory loss, which now I think is the culprit.
    Someone would need to correct me, but isn't the memory module in the seat? That could be the issue since it's now gone/different.
    ig 1red_b7
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    I also have B8 S-line seats swapped in, B7 to B8 use different memory seat modules i have not found a way to make it work as the module is no longer in the car or has any way to communicate over to the mirror.
    Just one little trade off for much better seating comfort, honestly hasnt bothered me not using it for 2+ years.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by a4audi4fun View Post
    ah that's why i don't have it
    1976 Yamaha XS 360
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Correct. Tilt is tied to the module under the seat. the module is just sitting there and you could grab it from the old seats. If you connect it to power, ground, CAN and K line you could likely get it to work again.
