Results 1 to 4 of 4
    Jan 04 2023
    CVT vs Automatic engine differences?
    Hello, I need to buy a new engine for my 2007 A4 2.0t Quattro B7 automatic. I found a good engine but it's from a car that had the CVT transmission. I was told by the mechanic that there was a slight difference between the two engines because of the two different transmissions (maybe the oil pan). Does anyone know if the engines are compatible with my car? Or if I have to change some parts to make it work?
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    The crank end is different. Manual/cvt are the same, auto tip is different. Some just install and get lucky, but better way is get a new tip bushing, and have it milled down(about 1mm all around), to fit inside the end of the manual crank. Thats after removing the pilot bearing. There is a thread in this group with the specifics.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Jan 21 2018
    frackville, pa US
    https://www.audizine.com/forum/showthread.php?t=635929
    Read around reply 50-60ish..
    Jan 04 2023
    Wow ok thanks Jay. I was told much differently. Do you know of a good source that sells those modified bushings? Looks like Brandon is MIA and if I was to attempt this engine swap I'd want to make it as simple as possible and not have to worry about finding machine shops near me.
