Results 1 to 3 of 3
    Nov 30 2010
    San Diego
    Very squeaky brakes
    Took new brakes to my shop for install and the guy goes “your brakes are fine and don’t need replacement” based on his visual inspection.
    But they squeak at low speeds. Any tips on what I can do to reduce noise without having to remove components?
    Would spraying down with brake cleaner do anything ?
    Senior Member Two Rings Jetta03's Avatar
    Jan 29 2020
    Generally can fix noisy brakes by following these steps....
    - rough up the brake rotors with a red scotchbrite pad
    - very lightly sand the face of the pads to get a clean surface and also file a slight chamfer into the leading edge of the pad surface
    - properly bed them in
    Generally these steps will fix most pad squeeks and slight vibration at the pedal.
    Cheers
    Nov 30 2010
    San Diego
    Anything I can do without having to remove my wheels and pads?
