Results 1 to 2 of 2
Thread: Drag wheel size
    Junior Member One Ring
    Jan 07 2023
    Tracy, CA
    Drag wheel size
    Hello All,
    Im trying to figure out what size drag wheel i can use for the strip. Ideally, I'd like to do a 17" wheel to cut the weight down. Will that size fit over stock disc's? I'm interested to see what others are using for the strip....also, what tires are you using? I'm looking more at drag radials since I might use it for street as well.
    thanks,
    Fred
    2016 A6/C7.5 3.0 CREC
    IE Stage 1 tune
    IE TCU tune
    IE Cai
    Magnaflow custom catback exhaust (11385, 2x 10415) to Black Armor dual tips
    Established Member Two Rings HolyHell's Avatar
    Mar 24 2021
    1986 GTi, 2013 S6, 2010 GTI, 1993 Toyota Truck
    San Diego
    I think 19 is the smallest that can be used up front and 18 is the size for the rear. Not sure about tire specs though
