Results 1 to 13 of 13
Thread: Midpipe 8y Rs3
    Feb 12 2016
    La
    Midpipe 8y Rs3
    Do the previous gen OEM midpipes fit the 8y rs3? I noticed some other manufacturers are running the same midpipes from previous gens. Just wanted to confirm.
    Dec 02 2020
    Austin, TX
    Quote Originally Posted by Klim89 View Post
    Yes the previous generation 8V RS3 midpipes are interchangeable to the 8Y RS3.
    Jul 21 2014
    United States
    Anyone verified the 8V OEM Audi catless midpipe? Or is there a new 8Y part number(s)?
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by GTItoS4 View Post
    Yes OEM and aftermarket fit, OEM 8V part numbers 8S0254502A & 8S0254503A.
    Stage 1 more than you RS3
    Aug 31 2021
    Oakland CA
    Are the exhausts the same aside from the tips?
    Senior Member Three Rings NapalmEnema's Avatar
    Jul 02 2022
    2022 Kyalami Green RS3
    Houston
    I just installed it, it fits fine - just a heads up it's pretty subtle unless you romp on it. Even then... So if you're thinking this will be enough and are an 'exhaust' person, it won't be enough lol. It sounds neat, and I feel the value is there for a couple hundred, but I'm getting an exhaust later this year, if that tells you anything.
    2022 RS3 Kyalami Green
    2017 M2 Performance Edition - Arctic White
    2021 Type R - Shadow Grey Pearl
    Established Member Two Rings Jcruz87's Avatar
    Mar 01 2017
    Tristate
    I have a uni midpipe on my 8y and can confirm that it's mild.
    Sent from my SM-S908U using Tapatalk
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I switched my 034motorsports mid pipes from my 2018 8V and they got perfectly on my 2023. It took me 30-40 minutes on a lift. No fitment issues, big difference on the mid pipes and my car even had the sport exhaust which makes absolutely no difference on the new 8Y.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Feb 12 2016
    La
    Thanks for the input guys
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    I have 8v Uni catted downpipe with uni catless mid pipes on my 8Y. They both fit perfect. Its still pretty quiet but sounds better in dynamic or when you are getting on it.
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Yes they do. Got the CTS one.
    -cW
    https://youtu.be/hXESoEnwPT4
    2023 X3 M40i Alpine White
    Jul 15 2022
    US
    Quote Originally Posted by NapalmEnema View Post
    I imagine it would be a greater difference for people that didn't get the sport exhaust?
    Jul 02 2022
    Houston
    Quote Originally Posted by grandpab View Post
    Would certainly be, and I don't hate it, it's just subtle. So if you're looking for a large change of sound, this may disappoint, but if you are just looking for a bit more grumble and some more bite when wide open throttle, this fits the bill.
