Results 1 to 4 of 4
    Established Member Two Rings 2002allroad's Avatar
    Dec 30 2007
    Chicago area
    what is this line called?
    Its located on the bottom when you look straight down between engine and front radiator. where is that oil leak coming from?
    2013 AR premium plus sports package, silver with matching fenders, 20% tint, Carbon vinyl wrapped interior trim, Dynamic side turn signals
    solowerks coilovers w/KW 30mm spacers rear, Niche M179 Verona 20x9 et25, 255/35/20, (winter) stock 18's with Blizzak w/15mm spacers, 10.25 Android (non Rsnav), wireless CarPlay
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by 2002allroad View Post
    I believe that you’re referring to one of the transmission lines that goes up to the cooler.
    Jul 16 2018
    Atlanta
    That's my call too; one of the ATF lines from the transmission to the ATF cooler in the radiator.
    https://audi.7zap.com/en/usa/audi+a4.../3/317-317060/
    Jul 07 2021
    New York City / Connecticut
    Quote Originally Posted by Smac770 View Post
    Yep. Trans coolant line that goes from the radiator, snakes around the driver's side of the engine, and goes into the trans right by where the steering column comes down. That line is also two pieces joined together; it's often one of the first things to go when you have a lot of rust under the car or a small impact to the drivers side. Mine is on its last leg lmao
