Results 1 to 9 of 9
    Established Member Two Rings austin1346's Avatar
    Jul 19 2022
    US
    Question Is this style "lift pad" safe to use on pinch welds?
    All the DIY shops near me have this style of lift pad and I'm hesitant to use it on my pinch welds given how fragile they are. Also metal on metal is rather slippery. I'm pretty sure there are frame rails underneath all the plastic covers but I don't want to deal with them if I don't have to. All the shops that have lifted my car always have some sort of rubber or slotted rubber pad to safely lift from the welds.
    Anyone have experience with this? Thanks.
    Senior Member Four Rings
    Jun 08 2021
    PA
    There are reinforced areas on the pinch welds. As long as they are placed in the right position they should be fine. Nearly every car on the road has been lifted by that style.
    Jul 19 2022
    US
    Thanks for the reply. How would you orient them? Are they supposed to run parallel or perpendicular to the pinch weld? I'm not sure if the reinforced part is as long as the pad/feet
    Jul 16 2018
    Atlanta
    Are they the best fit pad, no. Will you ever see shops spend the time to care, no. There's a reason pinch welds on often worked on cars are always messed up. The one on my niece's malibu was so smashed up, you couldn't even safely use the spare tire jack with it until I did some unsmashing adjustments.
    Pinch welds for lifting is cheap lazy piss poor solution to the problem. But do they have to care that want better for your car? No, so they aren't going to do jack about it.
    Jul 05 2015
    Lower Hudson Valley
    My shop uses blocks of wood. 🤷
    Aug 16 2020
    Q
    Yes, they're fine.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Buy a few of these and have them use it when lifting. It's what I do - https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Jul 19 2022
    US
    Used it today for the first time and can confirm it's fine and did not bend my welds. However it does peel a little paint off some spots but can easily be recoated with spray paint.
    Established Member Two Rings eyab689's Avatar
    Mar 15 2014
    upstate, ny
    When I'm using my floor jack I bought these round disks kind of like hockey pucks with a slit in them and it lifts at the pinch welds without any issues.
    Sent from my SM-F926U using Audizine Forum mobile app
