Results 1 to 13 of 13
    Mar 25 2020
    Coconut Creek, FL
    10k Mile Oil Change Interval after Turbo Screen Recall?
    I figured I would bring this up, since I haven't seen anything on it since the turbo screen recall. A lot of members here absolutely disagreed with Audi's specified 10k mile oil change interval recommendation. Many just simply don't trust changing every 10k miles, and also justified that stance with the turbo screen design flaw. Well, now that the design flaw has been "fixed", are we moving above 5k oil change intervals? Thanks.
    2013 S6
    Feb 15 2011
    Northern VA
    If you drive normally and don't regularly track your car (and have done the screen recall), 5K oil changes are overkill given the quality of modern synthetic oil and filters. Oil analysis after oil analysis proves this.. It's certainly not in Audi's best interest to recommend oil change intervals that will be detrimental in any way to the engine if they wish to keep their customers. Even oil companies recommend longer intervals. and they have the most to lose.
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    as for oil i go every 7k my car sees the highway more than city driving, if you get good oil and good filter shouldn't be an issue. I believe oil can handle things at 10k maybe even 15k under normal driving but i just don't think filters can <--my 2 cents which is worth only .5
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Dec 07 2022
    Houston Texas
    I am working with a company now to do an oil bypass filter. I want to remove the oil screens completely and do a bypass filter system. These systems have been proven to give most oils 20 30 or even 100k miles. Cost is looking to be around 800- 1000 plus install. Ill make a thread if i ever pull the trigger.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Quote Originally Posted by Krystofer66 View Post
    $550 for a kit from JHM
    https://jhmotorsports.com/stainless-...8-s8-4-0t.html
    Veteran Member Three Rings Botbasher's Avatar
    Jul 26 2018
    2014 S6 "Elsa" - Mk 6 JSW - Scratch Built Lotus 7 Replica
    Humidity, NC
    Quote Originally Posted by Valpo A7 View Post
    I think he's talking true bypass... not screen relocation.
    Correct Krys? That's going to be a lot of plumbing in a really tight spot!
    Interested in seeing what you come up with!
    Good Luck!
    KS
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Botbasher View Post
    I think I asked this question (true bypass) in another thread and the AZ engineers who responded did not think it would eliminate the turbo damage problem. I think qcrazy and gk1 have been disassembling their full flow filters to see what's being caught.
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    IMHO the 4.0T is just just a filthy motor. At least engine oil-wise.
    Where the filth comes from IDK exactly, but I feel it manifests itself in bits of carbon and debris that you can seen in the filter and obviously the screen.
    If 5k intervals helps keep the oil cleaner in any way, again IDK, but it is what I have done since new and it doesn't really bother me.
    When my screen was removed it was not as bad as some I've seen and whatever debris was there could have honestly just been from when the mechanic removed it. It also washed away with great ease and looked brand new afterward.
    Can that be attributed to 5k OCI, maybe, but others on here have indicated they do 5k intervals and their screens looked real bad. (shrug)
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jul 26 2018
    Humidity, NC
    Quote Originally Posted by Alabama View Post
    I would not think it would help in the larger scope, but new ideas come along all the time! Could also depend on placement in the flow to help catch more then not.
    The one great advancement I found in my quest for "forever" oil was when I was able to use Canton Oil Filters elements (cartridge replacement for spin-on). I started using them on a 1.8L JH Block and even at 10k miles my oil looked like I just poured it in. Not exaggerating... it was honey brown at 10k! Blackstone said oil was still perfect and said that it had at least 5-10k more in it! They were a true 8 micron filter where most OTS filters are ~40 micron
    Unfortunately they only have a few options that cover standard spin-on filters... nothing for more exotic filter designs.
    I pulled my S6 filter element apart on my initial change. Unknown age or mileage. There was nothing obvious in it. Black and silty but no chunks or other nasty!
    Cheers,
    KS
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Cheers,
    KS
    A few people have done a blackstone oil analysis with the 4.0t, someone doing progressive testing at 5/7/10k mile increments. Blackstone came back with pretty much what you stated at 10k; oil was great and could go for 5k more miles. This was without special oil filters and bypass systems.
    Simply stating there are clearly situational and specific vehicle differences, likely based on where the car lives(environmental factors play a bigger role than some think), gas and oil used, prior maintenance, etc.
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Jul 26 2018
    Humidity, NC
    Quote Originally Posted by gk1 View Post
    In wondering this same question with other IC motors and oil quality systems I have used in varied careers, I found the filth comes from basic filtering issues (~40 micron on auto filters) and temperature abuse in most cases of healthy motors. My "tests" were run on motors with better than 180psi compression, so blow-by was not a primary contributor.
    In the ^ post, I started using a HUGE oil cooler (almost 2L of volume!!) on a 1.8L motor that I regularly drove at it's limits. At 5k miles, the oil was visually dirty, but it had viscosity more on par with new oil than used. On long downhills, I could easily see temps below 140F. On those same uphills, the temps barely got above 210F even at full tilt (same hill hit 240+ before the cooler!).
    Then I took on the filtering aspect of the problem and started using Canton 8 micron filters. At 5k it was actually hard to see on the dipstick. At 10k it was honey colored and still 100% effective according to Blackstone. I ran it to 15k and finally gave up and changed it simply because it felt wrong to go more. I think it would have been a 20-25k oil interval!
    I think the 4.0tt motors cook the oil really bad. They take forever to warm up and stay hot a long time after pushed. I see 220F's after hard pulls and that's not what the temp is within the motor itself! When I did the oil screens, there was lots of burned oil in the valley. It smelled bad... real bad! I don't think there is a real way to combat that in this design. We can cool the oil more with larger or improved coolers, but it'll still sit in the valley and cook!
    The filtering is almost as hopeless. Unique OEM filters (Ours is only used in Audi and Bentley 4.0t motors) mean lack of options from suppliers like Canton who make amazing and effective filters!
    I'm still looking at the options that might help us with this motor, but it it doesn't really have a lot of possibilities at a quick glance!!
    Cheers,
    KS
    Dec 07 2022
    Houston Texas
    Yes Correct
    Dec 07 2022
    Houston Texas
    Is there any concern from lack of flow with a lower micron rating filter?
