Results 1 to 11 of 11
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    Steering rack ratios
    Anyone know how much quicker (if any) the B6S4 or B7S4 steering rack is compared to base B7 servotronic rack? Thank you.
    They're not scared of you. They're scared of what you represent to 'em.
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    not really 'quicker' but the force/feel is better
    https://www.audizine.com/forum/showt...ck-Upgrade-DIY
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT, 08 manual Titanium Avant
    frackville, pa US
    The s4/rs4 has a slightly quicker ratio. By how much, I can't rem. Was looking around when I replaced my rack, but wound up just getting standard replacement.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by xRenesis View Post
    They do have a "quicker" ratio. Less turns from lock to lock. Thats what ive read, unless it was bad info..
    Jan 14 2015
    South Dakota
    I do have an RS4 rack/642 in mine, it is so unnoticeable in my opinion for quickness, however the effort and response you get is
    *I can add about how many degrees/turns full lock is after work
    ig 1red_b7
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    2019 SQ5 Prestige
    Jan 21 2018
    frackville, pa US
    See, what ive read, is what you mention. But also that s4/rs4 are both 14.5:1, and a b5 rs4 was 13:1. Thats why so much confusion.
    Jun 17 2013
    jersey city nj
    I a B7 RS4 rack in the avant after my original started leaking. You can feel the difference when your aggressively around turns & manuerving
    Jan 14 2015
    South Dakota
    Alright so for me, one direction is 1 1/4 turn, so 2 1/2 total lock to lock.
    Same as vce though, original leaked and scored a deal. 4 years so far, and I want to say I checked it when installed to confirm it was an RS4 rack.
    ig 1red_b7
    Apr 16 2015
    CNY Syracuse
    It’s odd because my a4b7 has much tighter steering than my a4b6 yet they’re both supposed to be 16.3:1
    I should sit in both and do a turn to lock comparison.
    Apr 01 2007
    houston texas
    Quote Originally Posted by Gin+ View Post
    Your B7 is servtronic - so depending on the relay it may actually be 'tighter' at times.
    Along with the rack itself you also have to run the proper relays to get the most out of the mod.
    2019 SQ5 Prestige
