It is not plug and play from my understanding. That being said there is a gentleman, StorableComa, on the GolfM7 forum that has put together his own kit with harness and OEM plugs etc that is a lot cheaper, I think IIRC he can have you setup with an RS3 pump, harness, and all the fixens for 500. Don't quote me on that though, message him if you're interested. Beyond that you would need a custom tune. The pumps in our car, from what I am told do not have a low pressure side sensor, and so adding a higher volume pump could overwhelm your system with too much fuel. It's also likely to really get the advantage of an RS3 pump you would want to go MPI, otherwise it would be a waste.
