Results 1 to 4 of 4
    Nov 03 2018
    Estonia
    Audi A4 2.0TDI CGLC y2013 DPF regeneration issue
    Hello,
    Audi A4 2.0TDI CGLC Quattro..probably issue with DPF. At first i noticed that exhaust tips have black soot inside - never noticed this before.
    Checked with OBD11 what are DPF soot values. Measured value is always higher than calculated values. Usually after regeneration measured value rises to 20g within 70-80km. 20-24g until calculated value follows up and then regeneration takes place - usual frequency is 200-300km.
    One more thing I noticed is that when regeneration takes place...calculated value decreases in 20min until 1g has reached. Measured value decreses until 16-14g and then stops..even rises small amount. When I stop driving and car runs idle..measured value decreases until 6g grams in few minutes and regeneration stops. Basically it never stop regeneration while driving. Car usually drives on highway about 2 x 50km per day.
    Has anyone had similar issues or has an idea what could be wrong?
    Thank You!
    Feb 15 2016
    Cambridge,Ontario
    A4 was never released in North America as a diesel and that represents I would say 95% of this forum. Responses may be limited.
    I would suggest audiworld or a vw forum might yeild more results
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Quote Originally Posted by Raidokl View Post
    Hello,
    Thank You!
    What @Iceman said.
    You might want to post over at https://www.a5oc.com/forums/a5-general-q-a.2/ , which has a larger European audience.
    We have a 2011 Golf Variant 2.0 TDI that had similar frequent DPF regen behavior earlier this year. The local VW service determined a contributing factor was a failing coolant thermostat, which was not closing properly, thus engine operating temperature was rarely at spec (about 90C). You might want to monitor your coolant temperatures. Since replacing the thermostat (and the DPF) in October, our regen cycles have been much longer. --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Nov 03 2018
    Estonia
    Thank you Guys..
