Results 1 to 7 of 7
    Established Member Two Rings truethat72's Avatar
    Jul 25 2014
    San Antonio, TX
    **** ECS Tuning Luft-Technik Intake Air Scoop v2 ****
    I replaced my entire intake system with the APR Ultra Throttle Body kit so no need for this scooper. It is less than a year old.
    Original listing from ECS Tuning here: https://www.ecstuning.com/b-ecs-part...08184la01~akt/
    Asking $50 + shipping
    ////// 2014 B8 S4; Misano Red; DSG ; APR ECU Stage II with Ultra Throttle Charger; APR TCU; ECS Cold Air Intake; AWE Touring Exhaust with Down Pipes ; H&R rear sway bar //////
    ////// 2006 B7 A4; Black; 2.0T; 6MT; APR Stage I //////
    ////// 2004 B6 A4; Silver; 3.0; 6MT //////
    Senior Member Three Rings Dan92H's Avatar
    Dec 03 2019
    Chicago
    I’ll take it
    Mar 31 2008
    eS-4
    CAL*SO
    dude!! keep it!
    i modified my ecs lufatek stuff to fit my ultracharger.
    Jul 25 2014
    San Antonio, TX
    Quote Originally Posted by Fresh.S4 View Post
    dude!! keep it!
    According to my shop it won’t fit. How did you fit it?
    Mar 31 2008
    eS-4
    CAL*SO
    if you have the "closed" setup with the cover you can trim around the flex silicone area with a dremel. that lets you still use the lid.
    and to fit the scoop, it takes some measuring, and depending on what hx you have ( i have merc) and you can trim a small triangle section out of the middle portion where it angles down and it slides right over the corner of the hx.
    Mar 06 2019
    Indiana
    I’ll take it
    Jul 25 2014
    San Antonio, TX
    SOLD.
