Chiming in here because I struggled a few years ago getting a good bleed on my brakes.
I tried to MityVac vacc bleed and it worked ok but the pedal didnt feel right. So I made a pressure bleed with a second cap for the resevoir I bought on here.
I ended up splitting my resevoir open nowhere near the 2bar thats recommended and having brake fluid go everywhere below the resevoir.
I got a new resevoir and did a combo where I pressure bled in the order described(PassR, DriverR, PassF, DriverF) then did a sanity vacc bleed in same order cause I still felt like the pedal was soft. I ended up having to temporaily seal around the bleed screws with some heavy grease to keep air from working in through the threads.
I had just put reman'd calipers on all 4 corners, not sure if that contributed but I definitely got my pedal feel after the above step. I then bled the ABS using vag com. Didnt touch the slave cylinder tbh.
Sent from my SM-G973U using
Audizine Forum mobile app
