Results 1 to 11 of 11
    Dec 29 2015
    Nashville
    Salvageable Intercooler?
    https://youtube.com/shorts/JyHnP9ri8ko?feature=share
    It seems that a rock has claimed my intercooler recently and it's pissing all over the lower front end of the car.
    Any chance this can be repaired or just replace and install a rock screen/guard. I do tons of highway driving.
    Thanks
    Mar 31 2008
    eS-4
    CAL*SO
    very much salvageable!
    that happened to me a long time ago in a galaxy far far away..
    I did the repair while it was still mounted to the car, just make sure as much of the fluid has been drained from that hole. (it would be best to remove the hx to make sure its completely dry)
    but once the area is bone dry, mix up some jb weld and slap a glob over the pin hole (dont spread more than maybe a coin sized amount, enough to seal the hole). let it dry, refill fluids and you are good to go!
    PS) i heard in n out is gonna start showing up in your neck of the woods. enjoy!
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Might as well just upgrade to a bigger HE https://mercracing.net/product-categ...8-5-2010-2016/
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Dec 29 2015
    Nashville
    I got some WaterWeld that's three years old and has been opened. Should I just buy some fresh jb weld?
    Senior Member Three Rings JRYtheS4's Avatar
    Sep 08 2020
    You can get an oem spec intercooler for ~$200 shipped if you're not interested in modifying your car.
    Sent from my SM-G991U1 using Audizine Forum mobile app
    2011 Audi S4 Prestige 6MT|Full ADS w/ sport diff|Meteor Grey Pearl|Black/silver alcantara|Aluminum trim
    Bone stock except intake
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Also with so many users upgrading their intercoolers, I'm sure there is a massive amount of stock ones on the used market.
    Veteran Member Three Rings mahhdd's Avatar
    Nov 08 2020
    Atlanta, GA
    If I didn't assume it was absolute garbage, I would've given you mine.
    Wait, they are garbage... Upgrade to a MercRacing if you can.
    2015 Sepang Blue S4, 6MT, Sport Diff, Ceramic Coated
    034 Stage 1 Tune, Intake, UCA & LCA Kit, Springs, End Links, Drivetrain Mounts/Inserts, RSB, and HPFP Piston, Bilstein B8 Shocks/Struts, P3 V3 Gauge
    MercRacing S6 HX, CWA 100-3 Pump, JXB Shifter, Mount, Extended Slave, and Reinf. Linkage, USB Stainless Steel Clutch Line, ECS Resonated Valved Exhaust, Engine & Trans Skids
    Dec 29 2015
    Nashville
    I don’t do any tracking so no real need for an upgraded hx
    Nov 08 2020
    Atlanta, GA
    Quote Originally Posted by S4Mon View Post
    Even a stock car benefits from an HX on a warm day with back to back pulls. I saw timing pulled between runs. Just food for though. I appreciate the added heat safety on these motors though...
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by mahhdd View Post
    this.
    at the very least modification wise, the hx should be replaced with a bigger one.
    it has nothing to do with tracking.
    but
    if you absolutely need a stock one, i have one. check your messages.
    Dec 29 2015
    Nashville
    I threw some JB Waterweld on there for now and it is holding.....so far
