Originally Posted by
67Twisty
I didn’t notice a significant difference. When I did it the 034 seemed to be the only option other than stock OE replacement. My car is a manual and it may have reduced a bit of drivetrain slop, but also increased some NVH around the shifter in the cabin. Replacing the motor mounts and the snub mount had a much greater impact in tightening the drivetrain.
Thanks for the feedback. I have a B6 with what is essentially a B7 short block fitted with 1.8T stroker pistons and a B7 k04-064, B7 240mm dual mass flywheel and a B6 02X six speed (4.11 final drive). It pulls great and makes way more TQ from 2000-3000 RPM than the 1.8T. The down side is I get some type of harmonic vibration driveline right at 2650 RPM. I'm running the B7 rev driveshaft and tranny mount. Snub mount made no difference, swapping to RS4 engine mounts no change. Every time I swap a part in it seems to go away for a few days. A stiffer tranny mount was the next test. Putting in a new B7 mount did help... For about a week it was almost gone. I may put a go pro under the car to get a view at what is happening. Curious if others have had the same issue with the higher TQ output of the B7. Right now the only difference in my driveline and the B7 is I have a 4.11 final drive.
If I drop the boost back under 3000 rpm it goes away, and it only happens in the upper gears. Since its always at the same RPM is seems to be the time between pulses is causing it.
I have heard of others that had high TQ 1.8T's getting this, but never the 2.0TFSI people. The next move is a camera and possible simulate it in Ansys. Hoping to hear that someone had the same issue and solved it.
