034Motorsport's complete Density Line Control Arm Kit with Upper Adjustable Control Arms is designed to be a performance replacement for all eight of the factory front upper and lower control arms. Featuring high-durometer rubber bushings, high-quality ball joints, machined-billet upper adjustable control arms, and Aurora spherical bearings, this kit is engineered to limit unwanted deflection in the suspension. The result is tighter handling and more precise steering response than even brand new factory control arms can offer. In addition, adjustable upper control arms allow optimal alignment for your lowered or track driven vehicle.
The factory front control arms are an integral part of the suspension but can start wearing out as early as 40,000 miles - especially on enthusiast-owned vehicles driven hard on the street or track. As the rubber bushings degrade and ball joints develop play, alignment is compromised, and steering becomes less precise. This kit is a drop-in replacement with feature improvements over stock that will tighten up the front-end feel and allow camber adjustment to improve handling significantly.
Features:
- Complete, Drop-In Replacement for Factory Control Arms
- Offers Improved Handling Feel and Steering Precision
- Camber Adjustability Tailored to How Your Car is Driven
Camber Correcting
- Add Positive Camber to Achieve Factory Alignment Specifications After Lowering and Reduce Tire Wear
- +1.0 to +2.0 Degrees of Adjustment vs. Factory Arms (No Modification Required)
- -0.2 to +2.0 Degrees of Adjustment vs. Factory Arms (With Minor Clearancing of Upright)
- Black Anodized Finish
Track Spec
- Gain Negative Camber for Increased Cornering Grip, Better Turn-In, and Improved Handling
- -0.7 to +0.3 Degrees of Adjustment vs. Factory Arms (No Modification Required)
- -1.9 to +0.3 Degrees of Adjustment vs. Factory Arms*(With Minor Clearancing of Upright)
- Clear Anodized Finish
- High-Durometer Rubber Bushings (65 Durometer)
- Aurora Spherical Bearings Featuring Self-Lubricating Teflon Race Lining
What’s Included:
- Front Lower Control Arms - Front (Left & Right)
- Front Lower Control Arms - Rear (Left & Right)
- CNC Machined Billet Upper Adjustable Control Arms - Front (Left & Right)
- CNC Machined Billet Upper Adjustable Control Arms - Rear (Left & Right)
- Rubber Spherical Bearing Dust Boots
- Installation Hardware Kit
OE PART INTERCHANGE:
Upper Arms:
- 8W0407505C
- 8W0407506C
- 8W0407509B
- 8W0407510B
Lower Arms:
- Control Arm Front Left: 8W0 407 151 A/B/C/D
- Control Arm Front Right: 8W0 407 152 A/B/C/D
- Control Arm Rear Left: 8W0 407 693 B
- Control Arm Rear Right: 8W0 407 694 B
- Ball Joint Front Right and Left: 8W0 407 689 B
